Basic Wiring Question
CHIN10
Chinten
McKinney, Texas
2024 Jeep Wrangler Rubicon 392; 2018 Dodge Demon
Greetings!
It's been a while since I had my daily wrestling match with the electrical nightmare that was my 1987 Buick Grand National, so I may have forgotten a thing or two.
I wired up 2 pairs of DV8 cube fog lights on the hood and a pair of Baja fogs on the bumper. When I hook up a power wires to the cube light's positive wire, they give off tiny sparks (but doesn't pop the 30amp fuse). I see them if I gently rub the two positive connectors together. However, I don't get any sparks when I connect the Baja lights (or any other electrical connection like PowerSteps, rock lights, etc.) to the same power source.
I know I get some small sparks when I hook up battery terminals to a vehicle.
So I performed the following 2 tests after unplugging the wires at each light:
  • I hooked up a test light to a power source and connected it to the wiring. It did not light up.
  • I used a multi-meter to test for continuity with the ground. I got no measurement at all.
Question: Are the tiny sparks due to the power draw or is it because there's a ground in the power wire to the cube lights somewhere?
Am I missing a test?
Thanks in advance for your help!
-Chin10
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
The spark is the current completing the circuit. Just means the switch is on and your light is already grounded.
CHIN10
CHIN10
Chinten
McKinney, Texas
Excellent, thank you GATORB8!
-Chin10
