Barricade Rock Slider Install
xtraham
Long Island, New York
2019 Wrangler JL Unlimited
I'm installing Barricade Rock Sliders on my JL Unlimited, which requires removal of the body mounting bolts. When reinstalling those body bolts, should I use any type of Loc-Tight on them, or just re-insert and tighten down?
Thanks.
TexasJeeper
Jeremy
2024 Rubi 392 on order
Thanks.
I wouldn't put anything on them. I don't know if you have, but in case you haven't you should go the exterior section and look at one of the stickied post about broken body bolts.
xtraham
xtraham
Texas Jeeper, thank you SO MUCH for the heads up on the body bolt issue. I took your advice and returned the rock sliders. I'll look for something that doesn't require removing those bolts. Thanks again, God Bless.
Xtraham
Jondrew
Bob
Central Fl
2018 Rubicon
Xtraham
You may want to check out the LOD destroyer sliders. They are very nice and do not require you remove the body bolts. On that note, I will tell you many of us have successfully installed sliders using the body bolts. There are several threads in the forum (including one from me) showing how we did it.
TexasJeeper
Jeremy
Xtraham
Oh man, sorry, should have explained a bit more. I meant I wouldn't put thread locker on the bolt when you put it back in. But in anycase, it was going to be a gamble taking out the bolts. Some have had good luck, some, not so much.
xtraham
xtraham
NP, my JL is a replacement for a JK that I lemon lawed. After 10 months of Chrysler BS, I'm not into taking a risk with busted body bolts. I'm grateful for the heads up. I'll find something else to install.
