Baja Design Wiring Harness
Toemoe
Tomo
San Francisco
2020 Jeep Rubicon Recon
I recently purchased the Baja Design LP4 kit that includes 2 lights, 1 wiring harness for both light and a wiring harness for the backlight. I am a complete noob when it comes to anything electrical within the JL and would love some help from people that have experience.
I have a 2020 Rubicon Recon with the factory auxiliary switches. I want to hook up the lights to Aux 3 but the wiring harness from BD is throwing me off. Here is it look looks like:
Jeep Wrangler JL Baja Design Wiring Harness IMG_2171
So far I have figured out that 1 and 2 plug directly into the lights. 3 is the power and ground with a fuse. 4 is a relay and 5 is the BD switch. Can I remove 3, 4, and 5? Am I better off creating my own harness? If so, what will I need?
Like I said, I am a complete noob when it comes to wiring. If anything I said is incorrect, please feel free to call me out. I am trying to do this myself and learn in the process.
Flyper
Minnesota
19 JLU Rubicon
I am also a noobie and hooked up some Baja lights with that exact harness just a few days ago. I connected the positive wire from your #3 to the Aux 3 wire (the orange one) and the ground wire from your #3 to a ground point on the side and just bundled the other connectors together. All works great. I used this video for guidance on the Aux connection.
  • Like
Reactions: RJP
Toemoe
Toemoe
Tomo
San Francisco
This is extremely helpful! Thank you!
So you didn't cut any of the wires you did not use? For example, the Baja Design switch or #5 in my picture. You just bundled it all together?
WAOLIFE
Adrian & Josie
So Cal
2019 JLUM - 3.6L - Sky Touch & 2015 WK2O - 3.6L - IG: @wa0life
Fiddler of Parts
You should remove the switch at the very least, the fuse is redundant.
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
I chopped the hell out of mine after a call to BD. Since you have the switches already you can ditch everything but the wire to ground and the red and white. One of the two is for the back lit yellow. I put that to a different switch, not supposed to run those at the same time according to the destructions.
Toemoe
Toemoe
Tomo
San Francisco
Thats super helpful. Thank you! I might just give them a call to confirm everything before I start wiring. What number did you call? Were they helpful?
Gdub
Geoff
Tucson az
2018 JL Sahara
Engineer
I just called the number on the website. I believe I talked with a guy named Matt, but it has been a while. I put mine on a few months back.
Chile1
Missouri
2018 JLUR & 2016 BMW X5M
Biotech Sales Management
So where did you end up cutting the BD wiring harness? I have mine installed but with all of the extra cables (inc. fuse/switch). i now want to clean it up by removing all of the extras and connecting it to the BadgeGlow Simple Aux board for a cleaner set up.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
It's looks like that was one of those members who gets an answer to an issue and than splits until another issue comes up. Allow me to step in, as I've got some BD lights on my Jeep.
If your aux switch system already has its own built in dedicated relays and fuses, like the factory aux does, you can cut the harness right at the end of the lamp wires, right before they converge at the Baja relay and fuse section of the harness. If you don't need that much length, cut closer to the lamps.
Cheers, buddy!
Chile1
Missouri
Cheers, buddy!
If you don’t mind, would you mark in red where to cut on the following picture diagram.
Jeep Wrangler JL Baja Design Wiring Harness 1667167490884
Headbarcode
LI, New York
Plugs 1 and 2 go directly in the back of the lamps. Cut as much or as little of those leads that you need to reach your aux systems hookup point.
3 (inline fuse), 4 (relay), and 5 (toggle switch) are inly necessary when installing in a vehicle that doesnt already have an aux switch system.
Chile1
Missouri
Thank you so much!
