Badge fading
SadRobot
Los Angeles
2025 Prius LE
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
I wouldn't want them on glass because they'd block the view I'd imagine.
Absolutely, and I'm sure you'd get stopped by the police for having the windshield obscured.
Sidewalk
Josh
Riverside, CA
JLR
Local laws are pretty lax about that. You can cover a massive portion of the windshield in paint and still be legal. Pretty much the entire top 5" is a free for all.
Tokenwasp
Atlanta, GA
2021 Wrangler JLU 4xe Rubicon; 2008 Saab 9-3 Conv.
ha what's wrong with my placement?
Not a thing for normal people.
For OCD people, you filled the third row before beginning the fourth, so you have orphaned two "singles".
I have already reasoned to put mine on two at a time to avoid this - but even then, I would have four rows of two before adding a third to the ends of the third and fourth row.
(Yes, I realize I have thought entirely too much about this.)
SadRobot
Los Angeles
2025 Prius LE
Ha oh I had that same thought before I put them on. I wondered if I should wait until I got 3 to complete the row. I decided to just add it and I now have 2 more badges on the way.
My OCD shows in a different way. Like I can only have the volume of the stereo on an even number.
I also have spatial synesthesia which is kind of a fun form of ocd.
Tokenwasp
Atlanta, GA
....as God intended.
I'll say this, whoever decided that the two front seats should have two different temperature settings did not suffer from this problem.
SadRobot
Los Angeles
2025 Prius LE
My reaction when the result of my tire chalk test showed the perfect PSI was 31:
Jeep Wrangler JL Badge fading 200w
roaniecowpony
Retired Engineer
SPF 100 sunscreen mixed with 0w20 MS6895 motor oil. It's in the fine print. Your warranty is void. You probably used 5w30.
roaniecowpony
Retired Engineer
Same as my reaction when one of my tires shows it is one pound off from the others.
The surefire solution is to have Underground Graphics print a decal with all the same pressures and put it on the screen. I think he has an upcharge if you want all the same pressures. But it's worth it.
Terrymo
Terry
2023 JLURXR 3.6 ET
Brilliant!
sherpaJL
Keystone State
2019 JLUR Mojito! ~ 2022 JLUR Hydro Blue
i wonder if the ink was running low on that run of sch badges
The badges appear to be made using metalphoto.
They fade when they are not sealed properly at the end of the process.
