Back up lights not coming on.
777qlh777
Quincy
North Carloina
Jeep Wrangler Unlimited JL Sahara
I have upgraded quadratec led tail lights. The brake light works, the turn signal works. The reverse light is not coming on. I have checked every fuse, and even inspected the lights themselves. Everything seems to be in order. The only thing I can recall that may have caused an issue is when I was hooking up a trailer I saw a small spark when inserting the trailer connection. Does anyone have an idea what I should check or have experience with this?
Will_Jeep
Will
Atlanta
Black 2108 JKU Sahara, Black 2016 Mercedes CLS400
@777qlh777 How are you checking that they are on or not?
If I recall correctly, in order for the reverse light to come on, you need to be actually sitting in the drivers seat, with the door closed, and possibly even moving.
777qlh777
Quincy
North Carloina
Thanks. At night I am unable to see through the back up cam. So no lights come on, with me in the seat and doors closed.
SpeedKills
Bryan
Oklahoma
2019 Sport S 2-Door, 2008 Rubicon 2-Door,2014 Ram 1500, 2013 CRF250L
Have you checked your fuses? If you saw a spark you may have blown a fuse. Edit: I just noticed your post says you checked the fuses. Apologies for redundancy.
KO1159
Washington
2019 Jeep Wrangler JLU Sting Gray
Firefighter
Ever figure out what was going on?
