Aux buttons turning off?
DToxic
Blake
Bay Area, CA
2018 JL Rubicon
Hey guys, I'm using Aux 3 to power some rigid fogs. I've noticed after X amount of car starts, the aux turns off. It's not a huge deal because I'll just press the button to turn it back on, but I'm not sure why it's deactivating itself after some period of time on its own. Any ideas?
bmrrwolfe
Rob
Cleveland
2018 JLU Sahara 2005 Grand Cherokee
In the Uconnect, there are settings for each AUX button, is it possible that it is set to a time limit (say power on for 30 minutes)
DToxic
DToxic
Blake
Bay Area, CA
2018 JL Rubicon
good idea! but I'm not sure there's a time limit setting, but I'll check when I can.
Jeep Wrangler JL Aux buttons turning off? Aux Switch UI
1quick1
Moderator
Moderator
2018 JLUS
With this setting I would expect it to always be on unless you push the button again.
lookitsadam
Tampa, Florida
2018 JLU Sport
I have the same settings for one of my switches and never had that problem. Is it possible you're accidentally hitting the switch without realizing it when putting the Jeep in to gear? Or maybe your lights are tripping the fuse for that switch?
Ormond Beach, Florida
Retired at 55 ..
@DToxic
I have an Aux switch that is set-up to turn on every time i start the JL. Randomly, it will not turn on. I see it off and manually turn it on. This happens rarely but it does happen.
And no, I'm not bumping into the button and turning it off accidentally and neither are my passengers.
I take it as an occasional hiccup .. not a big deal.
DToxic
DToxic
Blake
Bay Area, CA
2018 JL Rubicon
@DToxic
Yah I confirm the same behavior. Not a huge deal. I was more worried if there was an issue. Like @lookitsadam says it might be a fuse tripping. But my lights are rated for around 3 amps and they’re the only device on the 15 amp aux cable so I have tons of headroom.
Thanks guys!
Retired at 55 ..
@DToxic
I have a mere radar detector connected to it and it rarely / intermittently does not turn on automatically as it should.
NathanG
Nathan
Tucson AZ
2018 JLU Rubicon
Once in a while your Uconnect reboots itself and resets the aux switches too the off position. Mine used to do it pretty often but lately only once a week or so.
DToxic
DToxic
Blake
Bay Area, CA
2018 JL Rubicon
Thanks all for the posts. Glad it doesn’t seem like an issue!
