At wits end over drivers prox entry
Deekykins
Derek
Alberta
2020 JLU
2020 JLU Sahara, prox entry from the factory which has worked perfect up untill about 1 week ago.
Tailgate and passenger door still work perfectly along with all other functions on the drivers door.
I’ve swapped the handle and end between the front drivers and passenger door, with passengers stills working with drivers components eliminating that.
I attempted to unplug the drivers side antenna, doing so disabled the other prox entry doors, leading me to believe that the antenna is functioning
Which leaves me the harness pins. They look straight and even. I’ve adjusted and tweaked and still can’t get anything.
Getting very frustrated as I really don’t want to take it to my substandard dealer and be given the run around at extreme cost, any suggestions are greatly appreciated
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Do you have access to a scanner that can do module scans? Any DTCs?
