As usual, simple is not - brake help
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
long Story, so I’ll cut to the chase. I have two rear caliper brackets, and don’t know which goes to which side. They appear identical, but I’m sure they are side specific. Only difference I can see is on is stamped 2132, and the other is 2123. Any ideas on how to determine driver versus passenger side? Added a photo. This is the 2123 bracket
Jeep Wrangler JL As usual, simple is not - brake help IMG_5067
BDinTX
Dallas, Tx
Taking a guess… the threading for the brake line is probably at the top?
ScotM
ScotM
Scot
Southern California
The calipers i didnt mix up. It’s the bracket I mixed up.😢. I added a photo to my original post for reference. Any help is much appreciated!
CO2Wrangler
21 JLURD
What brand are they?
For my JLUR, they are side specific.
CO2Wrangler
21 JLURD
I found an image online with right rear stamped 2264 so that probably doesn't help you. Also on my Rubi I don't see that number stamped on them. It has full part numbers.
ScotM
ScotM
Scot
Southern California
On the other side of my bracket there is a longer number, identical on both parts. They only visual difference in stamping was the 4 digit number
CO2Wrangler
21 JLURD
Possible it's a lot number that doesn't matter then? Same part # would lead me to believe they're interchangeable.
Terrymo
Terry
2023 JLURXR 3.6 ET
What’s the longer part number? What does it show on AllMoparParts or similar? I tried a quick search thinking odd ending part numbers would be driver and even passenger but I saw no pattern and some part numbers showed right or left.
Any idea if you can visually tell them apart?
I got nothing.
But if you lay them side by side and find differences, you can then compare to the calipers and backing plates.
ScotM
ScotM
Scot
Southern California
A005P276 which is linked to a manufacturer.
Jeep Wrangler JL As usual, simple is not - brake help Screenshot 2025-04-05 at 10.31.30 AM
If part numbers are visible, go to Moparpartsgiant.com and put in your VIN, then search. They identify which part number is left vs right.
ScotM
ScotM
Scot
Southern California
The only number available is not a mopar part number unfortunately.
