Alpine subwoofer replaced?
bem1
Blake
lantanapcguy.com
2018 JL, 2024 JL
Has anyone replaced their alpine sub with something better? Was wonder how difficult of a project that would be.
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
There are threads about this. I forget if some screw in or if you need a mounting ring, but it’s doable.
First is the rabbit hole of if you need an added amplifier, etc.
Terpsmandan
Penn Yan
There isn’t a lot of room in the enclosure, less than 3.5 inches. The most popular option seems to be the JL Audio 10TW3 4 ohm dvc sub. It’s only 3.25 inches deep and will work with the .5 cu ft enclosure. Pull the sub enclosure, remove the trim ring, remove the sub and don’t forget the one screw in the back. Then you can mount the sub on the trim ring and reinstall the trim ring. I will be doing this Friday after installing a MB Quart stage six and adding as 400.1 Quart amp to the rack. If you do this you will not be able to use the factory amp.
helpbyvinnie
Vinnie
Tampa
Jlu
Jeep Wrangler JL Alpine subwoofer replaced? 1000008856
Sounds better then expected.
If replacing sub I would add an amp
Add sound dampening and polyfill to the enclosure is a must of you take this apart anyway. Takes time costs little is worth it.
rforbes
Raymond
Seattle, WA
2024 Wrangler Rubicon X 4xe
I would think you would need to replace the amp to really make it much better.
Terpsmandan
Penn Yan
Quart came out with a drop in sub last year that is a companion to thier Stage 6 kit.
Txcomp
Tim
Northwest AR
2018 Rubicon
I have the MB Quart drop in in the factory box. I prepped the box with some deadener and stuffed with poly fill. The mounting wasn’t bad at all.
I’m using a JL Audio VXI 1000/5 sub channel to power the sub. At 2 ohms the woofer is getting about 600 watts. The sub sounds better than the factory Alpine sub but really doesn’t play that low. It pretty much falls flat on its a$$ at about 38 Hz but above that, it sounds good.
Overall, it’s a good upgrade that sounds better than factory but you’re not going to win any SPL contests with it!
Terpsmandan
Penn Yan
Agreed. I have had it for a year and I am happy. Could be better but considering the limitations of the stock enclosure, it works.
mrtm1970
Marshall
Orlando, FL
2019 JL Unlimited Rubicon
Mechanical Engineer
Anyone with Alpine drop in Sub have any input contrasting to this set-up and if it resolved low end bass issue/not there as mentioned above?
Terpsmandan
Penn Yan
I also replaced the AmpPro that came with the Quart kit with a Fosgate DSR-1 and the PLC2 knob. I like whatever curve is dialed into the PLC adjustment compared to the AmpPro knob.
