Adding wire to interior fuse panel
Furby
Tony
Hot Springs, AR
2019 JL 4dr Sport S
Can someone show me how to add a wire to the interior fuse panel? I know you can just use a fuse tap piggy back, but I want a cleaner look. All help is much appreciated.
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
Fuse tap is most common or you can splice/tap into an existing wire, if your addition will not overload the tapped circuit.
Furby
Tony
Hot Springs, AR
2019 JL 4dr Sport S
But can I run the wire to an empty spot in the fuse panel?
jlewissystem
J
STL
I have not done it in this vehicle, but i have in others, where they are marked "Spare". I'm sure they exist in the JLs. In that case, i would just use the fuse tap.
