Adding an Aftermarket Amp(s)
ziff73
Houston, TX
2020 JLUR & 2013 BMW M5 (former)
quick install question... PAC AmpPro AP4-CH41 RCA direct to JL XD700. no DSP.
do i want to enable or disable the 3 Band EQ in the PAC?
i'm doing passive components in the front and either passive components or coax in the soundbar.
ziff73
Houston, TX
Follow on question. HELP
i'm trying to install the PAC Amp and i have the harness all plugged in. I get the Jeep splash screen but then everything else is blank? no power to screen no power to PAC. i disconnected everything and reconnected factory harness and head unit works. do i have a bad PAC harness?
Sting_NC_USA
Sting_NC_USA
Michael
Birmingham, AL
Did you remember to plug the two Gateway plugs back in? They are the two modular plugs that go into the small box mounted on the back of the Driver's side speaker pod.
Let me know if that isn't it, and we'll dig deeper.
Sting_NC_USA
Sting_NC_USA
Michael
Birmingham, AL
You can enable it. If you had a DSP, then there's no need to enable it.
ziff73
Houston, TX
Haven’t even gotten that far. ’ve done is
1 pull out the head unit
2 disconnect the main harness.
3 Plug in the big pac harness to head unit
4 plug big pac harness to main Jeep harness that I pulled out of radio and
5 connected the pac.
6 connected the speaker wire harnesses on pac harness
Sting_NC_USA
Sting_NC_USA
Michael
Birmingham, AL
Two questions... How did you set the PACs Dip switches? Also, the PAC should be coming on regardless. Where did you pull power from?
ziff73
Houston, TX
Think I found the issue. The 3a fuse on the harness was fried. Does the fuse power the pac or for the amp turn on lead?
Sting_NC_USA
Sting_NC_USA
Michael
Birmingham, AL
Depends on which wire is involved. Radio powering on now? The PAC has to be on (when the harness is connected to the radio) for the radio to function.
ziff73
Houston, TX
You guys with the metra pods... are you installing the speaker grills or going naked behind the knee panels? Seems a bit tight. Should I be concerned about dust / debris if not using?
Thx
Liberty0rDeath
Justin
College Station, Texas
2019 Jeep Wrangler Unlimited Sport S
Thx
I did not put the speaker grills on mine. I didn’t try, but thinking back I don’t know that it would have fit if I had.
Sting_NC_USA
Sting_NC_USA
Michael
Birmingham, AL
Thx
I'm using the speaker's stock base plate, but that's primarily because I'm running 5.25's and the pods cater to larger 6.5's+. There's not enough room for the speaker grilles, because using the base plate pushes the speaker out quite a bit. It really boils down to how well your speaker fit's in the pod. If it fits fine without the base plate, then go for it bare. If not, add the base plate.
Either way, seal any extra screw holes you're not using, as they can whistle/buzz if you don't.
No concerns with dust debris, as the stock "grille's" holes are very protective.
FWIW, I do recommend using foam rings between the speaker and stock grille. Prevents sound from escaping behind the dash.
ziff73
Houston, TX
Hadn’t heard about the foam ring idea. What thickness did you use?
Sting_NC_USA
Sting_NC_USA
Michael
Birmingham, AL
I used these but purchased them locally. I cut them in half, because they're a bit too tall as is. They stick pretty well, just make sure they sit flush and aren't in the way of your speaker's travel.
Amazon has them on sale as of the time of this post: Fast Rings
