Adding additional back up lights. . .
MichaelR
Tupelo, MS
2020 Jeep Wrangler JLUR
I know this has been discussed but I'm adding the Addictive Desert Designs rear bumper with RIGID back up lights. . . .what is the cleanest way to get power to them? I only want the lights to work when in reverse. . . .
psdtime
Tom
2005 LJ Rubicon, 2016 Ram 2500 CTD, 2020 JLRU
I would use a relay. Have power from the back-up lights trigger the relay and run a hot wire from the battery with a fuse at the battery. Do you have the two package? If so, you may have a hot wire in that plug that you could use to power the lights and get your power from there.
MichaelR
Tupelo, MS
I do have the tow package. I was hoping someone had come out with a plug and play harness. . . . lol
psdtime
Tom
They might. I would check your tow plugs for a positive 12v source that is hot when the engine is running, if you have one, then you just need to tap the revers light positive and get a relay.
blnewt
New Mexico
Just ask @cosine he knows!
I'd just tap into the reverse wire (white w./ beige trace) on the drivers side taillight harness, simple :)
MichaelR
Tupelo, MS
I've read where some who tapped into the factory reverse lights had issues. . . .
Revolution_322
New Jersey
Jeep JL Rubi White
I would tap i to brake light wire on both sides done.
psdtime
Tom
That is why I suggest a relay. I don't know how much draw the reverse circuit can handle.
sandygar4
Gary
Oregon
2019 Wrangler Rubicon
I wanted the same as you, I tapped into the backup wire in the trailer harness by the plug. The wires are labeled on the larger plug. No issues with anything else.
Stetson
Salt Lake City
2019 JL Sahara, 2023 392 Rubicon, 2020 GMC 3500 Denali
Project Manager
I added some extra LED backups as part of a DV8 bumper I installed. I tapped into the trailer wiring harness. No issues, the lights come on when I shift into reverse. It was pretty easy to splice the lights in and everything works.
Stetson
