ABS error help
Grayhound
Michigan
Jlurd
I started getting an abs error while climbing a sand dune. Thought it was the sensor for the front right replaced it still get the error. Replaced the hub and still get the error.
What I’ve determined is I only get the error when breaking and turning right. Sensor tests fine , hub is brand new. What an I missing?
Grayhound
Grayhound
Michigan
Jlurd
Update: had help diagnosing and found a lead to the wheel speed sensor above the connection on the main wiring harness was broken. Reconnected it and heated it up taped it up and I seem to be good to go!
04yfz
NJ
21 Sahara 4XE
Any chance you can share a pic of the area you found this break? I am having identical issues and it’s the same sensor, happens when I hit bumps.
Grayhound
Grayhound
Michigan
Jlurd
Sorry I didn’t get pics. Just follow your wiring harness up from the connector.
04yfz
NJ
21 Sahara 4XE
How far did you have to go? Where the thin abs sensor end meets the bigger harness? Or further in?
Grayhound
Grayhound
Michigan
Jlurd
Not quite that far. I would jack up the frame near the area you’re having issues and that should give you clearance. From there you should be able to unwrap the wire harness and will probably fine a bare wire.
