3.6L ESS Battery Basic Load Testing
Jebiruph
Jerry
Iowa
2018 JLU, 2019 KL, 2020 JT
Checking the voltage of the batteries is a good start, but a battery with good voltage can still fail when under a load. To really test the batteries, you need a load tester. Some auto parts stores will load test your battery for you, but having dual batteries complicates the testing. To do my own testing, I found a cheap load tester online for less than $25. Harbor Freight has them too (plus free voltmeter with coupon). These cheap load testers are basically a heating element (uses a lot of power) shielded in a metal box with a voltmeter built in. It's not a sophisticated load test, but it's better than nothing.
The testing is basically the same as testing voltage. The difference is after everything is hooked up, you press a button to turn on the tester and place a load on the battery. If the voltage of the batter drops too low under load, it's a bad battery. The tester should only be turned on briefly, just long enough to read the voltage. This first picture shows the tester heating up when left on too long. It will melt plastic, so be careful. Mine turned the magazine it's sitting on brown from the heat.
To test, I disconnected the main battery positive terminal to isolate the batteries and used a digitalt meter to read voltage (instead of the meter on the load tester). Here's testing the Main battery with the tester connected to the positive post and the negative terminal. Normal voltage was 12.68v, loaded test voltage was 11.33v.
Here's testing the Aux battery with the tester connected to the disconnected positive terminal and the negative terminal. Normal voltage was 12.41v, loaded test voltage was 10.59v.
The meter on the tester indicates the good/bad voltage ranges. Both the 650 amp Main and 200 amp Aux batteries passed the load test.
(updated 04/13/2019)
Additional 3.6L ESS system information is available here.
3.6L ESS Dual Battery Consolidated Information
https://www.jlwranglerforums.com/forum/threads/3-6l-ess-dual-battery-consolidated-information.2
Jebiruph
Jebiruph
Jerry
Iowa
First, thanks for posting on the loneliest thread on the site. :)
The load tester I used was 100A and I think that would be good enough and can be safely used on smaller batteries. Mine is a Schumacher BT-100 100 Amp Battery Load Tester. It's no longer available on Amazon, so I can't post a link.
demisx
Dee
Desert Hot Springs, CA
Wrangler JLU Rubicon
These were my results on 2021 JLUR 3.6L/manual with dual battery/ESS. Looks like both batteries (2.5 months old) are still pretty good. Thank you for such a valuable post.
On a side note, this forum should add "bounty" or "beer money" feature. I'd love to leave a few bucks for those who make such valuable contributions to the Jeep community. I am sure there will be others too. 👍
jeepdabest
Bobby
Arizona
2019 JL Sahara
@Jebiruph
Can you test aux without removing pos ? I thought you could just read neg on disconnected aux
Jebiruph
Jebiruph
Jerry
Iowa
@Jebiruph
Either the positive or negative can to be removed to separate the batteries so they are no longer in parallel.
Fudster
Elliot
Athens, GA
2019 Sahara
@Jebiruph
Bobby, you can definitely test the aux battery without removing that piece of "ship."
Wait...."pos" is short for "positive" here, isn''t it? ;) You don't mean p.o.s. do you?
