beachjeepguy
- Apr 17, 2022
- Jensen Beach
- 2022 JLU
which site shows it is at D1?Yep, mine hit D1 5/23.
One of the tracker sites i found on this forum. D1 means “scheduled” for build I believe.which site shows it is at D1?
I got it from the Jeep tracker but the Jeep site matched.Are you seeing the status update on other trackers before the Jeep site or is this info coming form the dealers directly
Good to hear! Congrats!Yep, mine hit D1 5/23.
can you share the link to the tracker site you're referring to?One of the tracker sites i found on this forum. D1 means “scheduled” for build I believe.
jeeptracker.comcan you share the link to the tracker site you're referring to?
waitingforjeep.comcan you share the link to the tracker site you're referring to?
Yeah, I’m right there with you! No patienceI guess a 2 door, manual, rubicon x is likely at the back of the line. Patience is not a strong suit of mine. Ha!
I find that by refreshing the tracker 1,589 times a day I can make everything go faster!I guess a 2 door, manual, rubicon x is likely at the back of the line. Patience is not a strong suit of mine. Ha!
Since 5/9/2023, I’ve only checked 592 times. I better start putting in some work!I find that by refreshing the tracker 1,589 times a day I can make everything go faster!
Same!!I find that by refreshing the tracker 1,589 times a day I can make everything go faster!
