Paulcardona
Hi guys, i live in Colombia, South America, because the market is somehow small, Jeep doesn´t gave us the option to spec a new vehicle the way you wanted.
You just go to the dealer and pick a color (At least that was the option before Covid)
So, i ended buying a 2023 Sahara with "Colombian" Specs.
It come to my knowledge that, for some reason it didn´t come with the regular Sahara Grill.
Check this out:
But that´s ok, i can live with that...
My question, and believe me i´ve searched and read all the forum and had no answer for this:
When i looked into the Build Sheet with my Vin number i see the SelecTrac option, my car has the 4H AUTO option and everything, but i couldn´t find the LSD.
I thought, and correct me if i´m wrong, that the LSD was "obligatory" for 2023 builts when you choose the SelecTrac option, At least in the Jeep webpage.
If that wasn´t bad enough, i found on my vehicle equipment sheet from FCA:
- 2.72:1 SELEC-TRAC FULL TIME 4WD SYS
- DANA M186 FRONT AXLE
- 3.45 OVERALL TOP GEAR RATIO
- DANA M200 REAR AXLE
- CONV DIFF FRT AXLE W/DISCONNECT
- CONVENTIONAL DIFFERENTIAL REAR AXLE
So, no Dana 44 rear axle, no LSD BUT for some reason i do have SelecTrac.
Can somebody explain me this? It´s possible somehow that the vehicle equipment sheet from FCA webpage is wrong? or you can have SelecTrac with no LSD and no Dana 44, contrary of what i´ve been reading here?
Thanks a lot for your help!
Check this out:
