ARB4X4
- Ryan at ARB
- Mar 30, 2023
- Auburn, WA
- Website
- arbusa.com
- Jeep JL, Jeep JLU, Jeep JLU 4XE, & Jeep JT
Up to $250 rebate on Air Lockers.
Valid on purchases made between Feb 19 to Mar 17, 2024.
Buy 1 Air Locker, get $100 rebate.
Buy 2 Air Lockers, get $250 rebate.
Air Locker Application Guide
Shop Air Lockers
The ARB Air Locker Difference
What sets the ARB Air Locker apart from other locking differentials on the market?
1. Durability: Built to withstand the rigors of off-road driving, the ARB Air Locker is constructed from high-quality materials and engineered to handle extreme conditions. Its two piece case, forged gears, and timed locking mechanism makes it the strongest locking differential available.
2. On-Demand Activation: One of the standout features of the ARB Air Locker is its on-demand activation system. Unlike some other locking differentials that remain engaged at all times, the ARB Air Locker can be engaged or disengaged with the flick of a switch. Unlike other selectable lockers, the ARB Air Locker can be actuated at any speed as long as the throttle is not engaged. This versatility allows drivers to maintain optimal control and maneuverability in various driving conditions, switching between locked and unlocked modes as needed.
3. Air Operated: As its name suggests, the ARB Air Locker is operated using compressed air. This pneumatic system offers several advantages, including rapid engagement and disengagement, minimal maintenance requirements, and compatibility with onboard air compressor systems (a crucial piece of equipment for any 4x4). Additionally, the use of compressed air eliminates the need for complex wiring or hydraulic components, simplifying installation and reducing the risk of mechanical failure.
From the push of a button, air flows from the compressor to the differential. This compressed air pushes against a seal to drive the internal clutch gear which then locks the internal spider and side gears. This patented locking system only allows the locker to be locked in the strongest position possible, which increases the strength by up to 40%. Once locked, each tire begins to move at the same speed giving the vehicle equal traction when needed.
4. Compatibility: Whether you drive a Jeep Wrangler, Toyota Land Cruiser, or Ford Ranger, there's a good chance that ARB offers an Air Locker solution for your vehicle. There are over a thousand different Air Locker applications available across hundreds of vehicle platforms.
5. Proven Performance: Over the years, the ARB Air Locker has earned a reputation for delivering exceptional performance in the most demanding off-road conditions. From the deserts of Baja to the rocky trails of Moab to numerous Ultra4 and King of the Hammers victories, countless off-road enthusiasts rely on the ARB Air Locker to conquer obstacles with confidence.
Shop Air Lockers
