New Brushless ARB Twin
Terrymo
Terry
2023 JLURXR 3.6 ET
Looking at the dimensions of the new ARB brushless twin vs the original I see the brushless is noticeably larger based on the specs from your website. What mounting options will be available specific to the Jeep JL in light of the new larger size? Specifically will the new unit be mountable under the passenger seat with an ARB designed bracket?
Joker-7
Michigan
2020 JLUR
I would like to know if it can be mounted under the hood, or by removing the left fender and installing it where alot of people also install it. If it cant be mounted in those areas, I'll just have to go with one of the older models.
ncflyer
Cody
NC
24 JLU Rubicon
Did some rough measurements based on the dimensions on the website. It may just fit between the seat rails but stick out further into the rear seat area with the vents there and height looks to be too tall unless maybe seat jackers were used (just a guess not looking at difference with and without). Might be doable in the rear cargo area but would sit above the floor and may have to cut the plastic to squeeze it in the larger side. I'm sure someone will come up with something if folks want to wait or someone here works it out.
