GarageJimmy
North Carolina
2016 Tacoma, Working on a 392
Hey all, just sharing some notes on my experience setting up a DIY hoist in my garage for the hard top. Took delivery of my new 2024 Anvil 392 last week and absolutely loving it. First project was to make sure I could get the top off by myself to enjoy the nice October days before it gets too cold.
Basic parts list:
My main challenge was that I don't have a ton of clearance between the garage door and the ceiling - only about 39" of space there. The top is 25" tall at the highest point. Adding in space for pulleys, straps, etc, and things get tight quickly. As you can see, my first raise was pretty close.
I tried several different methods to attach the cables to the H frame. The first try was with clamps, but this failed because the cables don't stretch equally and they interfered with each other at the connection to the hoist cable. It also takes a lot of line to set those clamps up right and this didn't leave enough clearance. I tried some really strong braided rope but it stretches way too much and I couldn't get a knot working that got the frame close enough to the ceiling anyway. Finally I bit the bullet and bought a swaging tool and used crimp style fittings that work really well. I drilled holes at the intersection of the H frame and ran the cable down through the hole, using a cable stop on the other side. The loops that attach to the turnbuckles and hoist cable are doubled up.
I will also share that I tried hard to make this work without using turnbuckles because technically they are not for overhead lifting like this. It's just not possible to get these cables perfectly aligned and crimped without them. It's a risk, but each of these can handle working loads of 275lbs so they are more than strong enough.
While the setup is really stable and seems to work fine, I'm all about fail safes so I tapped two extra eye bolts and use those ratchet straps across the front and the back to get some extra lift, keep it level, and have a backup support in case my fittings end up slipping. The ratchet in the front just ties in with the existing garage door brackets. All in I think I have about $400 in materials and tools here.
Jeep Wrangler JL DIY Hardtop Hoist Garage Setup Complete IMG_5136
Jeep Wrangler JL DIY Hardtop Hoist Garage Setup Complete IMG_5127
Jeep Wrangler JL DIY Hardtop Hoist Garage Setup Complete IMG_5126
Jeep Wrangler JL DIY Hardtop Hoist Garage Setup Complete IMG_5130
Takes me about ten minutes to take the top off or put it back on, all in, and it's easy to do by myself. Just sharing all this in case someone out there is wondering if they have enough space or not to do something similar. If I can help answer questions, let me know.
Murphydog
Seattle
2020 X3M, 2023 JLUR XR
Nicely done! Looks like you have a bit more room to work with. In my garage I have to line up the soft top just right to fit under my hard top. I think next summer I may try to change things up a bit and see if I can get a few more inches of space.
1Evil55
here
2018 Sport
Nice work piecing the kit together. For what you've invested into it, why not just get an off the shelf lift like the Harken?
GarageJimmy
GarageJimmy
North Carolina
Thanks for the compliments, guys. Mostly I just like doing projects like this. Designing it and building it is 90% of the fun! I looked at a bunch of kits and almost went with the Lange but ultimately felt like I wanted total control over how it was set up.
Grayhound
Michigan
Jlurd
That would be so nice to have the space above the door like that! I did something similar but I used a much smaller hf hoist! Love being able to pop it in and off solo and quickly
Jeep Wrangler JL DIY Hardtop Hoist Garage Setup Complete IMG_1760
Jeep Wrangler JL DIY Hardtop Hoist Garage Setup Complete IMG_1756
Jeep Wrangler JL DIY Hardtop Hoist Garage Setup Complete IMG_1752
GarageJimmy
GarageJimmy
North Carolina
Ha, yeah I don't think your top can fit over that door.... Nice job solving for it though! Adapt, overcome
MaskedRacerX
DT
Florida East Coast
'24 Wrangler Rubicon 4xe
Yeah, I did a DIY too, all parts from Amazon:
Jeep Wrangler JL DIY Hardtop Hoist Garage Setup Complete 1696004106651
440 lb electric hoist for ~$100
I used brackets/track from Unistrut that allow the position to be easily adjusted - and if you wanted, you could run a few sections of the track and use roller trollies and be able to move it back out of the way or forward up over a door, etc.
A couple of HD straps (and I used an extra, smaller "safety" strap), some big carabiners, I think it was about $200-220 in parts.
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
I didn’t get as fancy as you guys did. But that’s what $50 at Home Depot got me. Even went back and got more supplies to rig one up for the wife’s jeep.
I did about the same.
Jeep Wrangler JL DIY Hardtop Hoist Garage Setup Complete 20200405_135224
cOtter
Southern, Indiana
‘20 Sahara 2.0L Ocean Blue Metallic, Toyota Highlander & Pontiac G6 coupe
Senior Manager PM (Automotive OEM)
Looks nice. Enjoy!!!!
I also put up a hoist for my 4 door hard top. 4 ratchet straps and 4 eye bolts. Under $30 total. Allows me to take my hard top off my Jeep by myself in less than 10 minutes.
blnewt
New Mexico
Just ask @cosine he knows!
Love the way you put that together to maximize that space above the opened garage door, superb, and had one inch to spare (but not a millimeter more :) )
Nice work, and nice 392 for sure!
WINNING!
rdk5
NJ
2024 Jeep 392
Picked up the garage smart second hand for half off. Finding studs through 2 layers of drywall was a pain.
Jeep Wrangler JL DIY Hardtop Hoist Garage Setup Complete IMG_2174
Jeep Wrangler JL DIY Hardtop Hoist Garage Setup Complete IMG_2176
Ahre
Paul
Livermore, CA
2020 JLUR, Ordered Mar 14, 2020
Very nice Jimmy,
Make sure you lockout the garage door when lifting...
