My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now...
MntGoat
MntGoat
Doug
TN
2022 Rubicon
Machinist
Been busy, got a camping trip coming up and I hate tents for 1 person...thanks Uncle Sam ;)
Any how, so have had headlight issues since I got her, weird flickering, or are they on???
SO I had to take the grill off...🤔
Popped the top retainers and a quick pull, and it came off w/o having to take the bumper/winch off for a damn headlight bulb.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260114_192933
Pulled driver side off and saw this as soon as I twisted cap off.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260114_195054
Yup, loose and it is a factory QC thing, notice the perfectly clean parts, and blue locktite was not broken
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260114_200639
So, I have white headlights now, and they are not blinding, we both drove it at each other. yes they are a cheap led, it fits great with the "jeep grill diffuser" good.
Driver side is new bulb and the 1976 headlight is on the passenger side
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260114_213713
MntGoat
MntGoat
Doug
TN
2022 Rubicon
Machinist
I installed my GMRS radio and temporally mounted an antennae .
I installed a Midland MXT115, a Midland 21-406 Ext. Speaker.
Disclaimer all the power points are temporary cigarette lighter plugs. Not a lot of time.
So, I match drilled all the holes for a very tight fit in the plastic for my bolts, this will allow almost zero mount movement or vibration in the plastic to mess up hole diameter over time.
Found a spot on the steering column kick panel, that fit with no blind holes. I prefer to match drill and bolt brackets to plastic.
1st draw a line on tape to mimic mount,
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260113_193840
then open up mount to the diameter you need...see above picture.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260113_194047
Me? I am an American, so I used 10-32 bolts, washers, lock washers and nuts.
WHY? Because all the uni-bit things have always been SAE instead of Metric
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... unibit
So, a 10-24 or 10-32 bolt is basically .187 diameter.
The uni-bit can cut a 3/16 or .187 thru metal like the mount, and then set the pre drilled mount on plastic panel. tape or clamp and then drill the 3/16 holes thru the plastic, you will have a nice burr on the back, dont de-burr it.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260113_194343
Screw the bolts thru the mount and the tight NOT deburred holes, washer etc....the extra plastic from the hole , will act as a thread locker combine with old skool lock washers
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260113_194651
Done, snap into place.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260113_194748
Installed, I can see the face while driving straight, which should be the only time you would actually look at it
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260115_183827
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260115_183748
MntGoat
MntGoat
Doug
TN
2022 Rubicon
Machinist
This is a picture of the Ghost mounted, It will change to center of hood probably after the trip.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260115_183803
MntGoat
MntGoat
Doug
TN
2022 Rubicon
Machinist
Took the driverside rear door off to remove the fixed glass.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260115_172537
pulled glass out.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260115_172801
WTF jeep? A full tube of glass glue for 1 little windows 🙄
So to say this was a PITA is an understatement I'm just glad I didn't say F***** and break it, because lots of blood would of been sacrificed to get all the glued pcs out.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260115_182106
Next? Waiting on the giant swooping blue penis to show up next Tuesday.
MntGoat
MntGoat
Doug
TN
2022 Rubicon
Machinist
Worked on my "changing seat/area"
Welded up mounts using stock mounting points, in and out in a minute or so. This inside camping area will be very modular.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260117_191458
Added an extra inch of hight with seat mounts, so its easier to put boots on and off.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260117_191236
Glued and attached. Very strong and solid.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260117_212034
This shows ht.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260117_212043
MntGoat
MntGoat
Doug
TN
2022 Rubicon
Machinist
Worked on heat this evening.
Took some measurements to cut a panel (if I can thaw the water tray) to replace fixed glass panel I removed.
Took apart the heater.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260119_215032
I tightened a few bolts, fixed the kink in the line.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260119_212110
Kink and no grommet, this would of been a pain in the ass from the get go.
I couldn't get in to drill a straight hole, because all the rivets wouldn't let me take it apart with out drilling them out and then replacing them with bolts or rivets, days are ticking away.
I couldn't get a drill bit in, and drill a proper hole for a grommet, so I cobbled this together.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260119_215808
and 2 layers of plastic wire loom cover and some tape, should be good.
I turned all the cheap hoes clamps so they wouldn't rub on the hoses.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260119_221940
MntGoat
MntGoat
Doug
TN
2022 Rubicon
Machinist
Been awhile never posted camping trip pictures here.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260131_074140
It was nice and warm -5*
MntGoat
MntGoat
Doug
TN
2022 Rubicon
Machinist
Started to revamped an old trailer for a canoe and camping gear hauling.
I built this maybe 20 years ago. I got it out.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260517_104858
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260519_100840
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260517_104901
MntGoat
MntGoat
Doug
TN
2022 Rubicon
Machinist
I cut off the upright and horizontal
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260519_134531
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260519_134503
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260519_134456
tubes that had swelled and froze over the years.
On the back, that horseshoe thing was a hold down and lock for propane.
Covered storage for grill, paddles, life vests etc.
From hitch back you can see the old cooler mount, down low.
MntGoat
MntGoat
Doug
TN
2022 Rubicon
Machinist
I cut off the tubes that had swelled and froze over the years.
Mostly stripped down. Need to get some seals
and bearings, then I hope to cut up the 3rd member for clearance.
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260519_141453
Jeep Wrangler JL My JAALA...Lets get back into wheeling...mama is back on board...so its a couples thread/journey now... 20260519_143447
I know panhard bar is crazy angle, BUT it's so light it just moves up and inch or so. Tracks great and has alot of miles on it.
