The Never Ending Journey to a Two Door on 37s - C1
AgentWolf
Tyler
Seattle, WA
2019 Jeep Wrangler Rubicon
I purchased my black two door Rubicon in October of 2019 and immediately took it off road. I will list the mods thus far and some pictures leading up to said mods. Feel free to ask questions if you are curious about a part or why I went a certain path. I off-road nearly every weekend and this vehicle is also used for SaR.
Stock:
First set of mods:
Armor:
1. Rock-hard 4x4 Stubby aluminum front bumper with winch bar.
2. LOD full rear bumper with Rigid D floods.
3. Rockhard 4x4 rock sliders, angled.
4. ACE Wide fenders.
Nice to haves:
1. ACE front fender liners.
2. JCR rear fender liners.
3. Smitty X20 9.5k synthetic winch.
Some minor additions that took some time:
1. PRP seat covers:
2. 8.4in screen install (had 7in from the factory):
3. Factor 55 Splicer and winch cover:
4. HAM / DMR Radio:
Anytone -ATD578UV
Will add a picture here
5. Taser JL
6. Mopar Tailgate Table
New wheels:
I went with method 701 in bronze. Having the backspacing of 4.5 was a requirement for my planed lift and mods.
I have had as low as 1 psi before with out popping a bead, possibly due to the internal bead grip.
ACE Stand Alone Tire Carrier:
Lift, Steering, Support Components:
Synergy Jeep JL/JLU Front Lift Coil Springs, 2-3 Inch Lift
Synergy Jeep JL/JLU Rear Lift Coil Springs, 2-3 Inch Lift
Synergy Jeep JK/JL Snap-Lock Bump Stop Spacer System
Synergy Jeep JL / JLU / JT Front Sway Bar Links with Quick
Disconnects
Synergy Jeep JL Rear Sway Bar Links
Synergy Jeep JL Rear Sway Bar Drop Brackets
Synergy Jeep JL Front Sway Bar Link Relocation Brackets
Synergy Jeep JL / JT HD Adjustable Front Track Bar
Synergy 2018+ Jeep JL/JLU Rear Track Bar Relocation Bracket
Synergy Jeep JL Parking Brake Cable Relocation Bracket
Synergy Jeep JL Heavy Duty Drag Link Kit
Synergy Jeep JL/JT Front Track Bar and Sector Shaft Brace
Synergy 18+ Jeep JL Adjustable Front Lower Control Arms
Synergy 18+ Jeep JL Adjustable Front Upper Control Arms
Synergy Jeep JK/JL Adjustable Rear Lower Control Arms (Pair)
Synergy Jeep JK/JL Adjustable Rear Upper Control Arms (Pair)
Synergy Jeep JL Heavy Duty Tie Rod
Fox Performance Series IFP Shock, 2018+ Jeep JL, Front, 3.5-4“
Fox Performance Series IFP Shock, 2018+ Jeep JL, Rear, 3.5-4”
Standard Travel Steering Stabilizer, Eyelet Ends,
PS, 2.0, IFP, 8.1“
Synergy Jeep JL Steering Stabilizer Relocation (High steer)
Kit for Synergy Tie Rod (1.5” OD TR Clamp)
Synergy Jeep JL/JLU/JT Front Track Bar Relocation Bracket (Just released, pending fabrication.)
From the components I have received these parts are the real deal. Possibly the beefiest I have seen.
The front truss is Artec "Front Axel Armor"
The rear truss is CavFab
Problems:
1. Steering box was garbage and I was one of the first in WA to get the steel replacement. This fixed the issue. See my thread on this about how bad the install process was as my dealer installed the old box and gave it back to me saying the new was installed.
2. 4WD stopped working on a gnarly trail and ABS locked my rear driver tire up. It threw a transfer case error. The dealer replaced the sensor in the transfer case and it has not happened again.
3. Randomly the seal between the windshield and freedom tops allow a wind noise. This happened one day as I was driving and can not find the reason why. The dealer replaced the freedom top seals but did not fix the issue. It will go back in eventually.
4. LOD bumper and rear fenders did not work out together and had to cut the rear fenders..
5. LOD rear license plate mount destroyed the paint and was removed. This is the reason I zip-tied my plate to my wheel and now have it attached to the new tire carrier.
6. Frame and axel are rusty and the dealer refuses to repair even after escalation. I live in an area with no salt, vehicle is kept in a underground garage and regularly washed.
7. Trees like to yank the rear tail-light guard. It has been ripped out before. I might remove them.
8. Hyper flash and turn signal light warning due to the aftermarket fender lights.
9. Occasional popping from the hand brake.
10. ??? I'm sure there will be more as we go!
dapipp
NW Idaho
2006 Jeep Wrangler X (TJ), 2006 Jeep Wrangler Unlimited (LJ), 2019 Jeep Wrangler Rubicon (JL)
I feel your pain with #9. Mine makes popping noises more often than I care for, drives me crazy.
AgentWolf
AgentWolf
Tyler
Seattle, WA
  • Thread starter
  • Thread Starter
  • #3
I’ll see if I can find out what it is. I have to relocate the cable.
Uranus
Cassie
Ypsilanti MI
vm.tiktok.com
Jeep Wrangler JL 4 Door Sport
Nurse
What tire size and brand are you running? I am looking at these same wheels.
Kreepin1
Kirk
Central Illinois
1982 CJ7, 2006 TJ, 2012 JKR, 2021 JLR
Really nice build! I was looking at Synergy too. Have you decided between the 2" and 3" springs yet? I'm thinking 2" is the way to go on a 2-door with 37's...
AgentWolf
AgentWolf
Tyler
Seattle, WA
  • Thread starter
  • Thread Starter
  • #7
I believe they will end up being around 3inches not including weight on the vehicle. I talked with Dave and he noted that I would want this height for the high steer and to flex out the 37s
AgentWolf
AgentWolf
Tyler
Seattle, WA
  • Thread starter
  • Thread Starter
  • #8
Both axels out today to get the trusses welded on. Lift coming soon!
So glad to have friends that know how to weld.
AgentWolf
AgentWolf
Tyler
Seattle, WA
  • Thread starter
  • Thread Starter
  • #9
Front truss and armor welded on Sunday. Painting this week then going back in.
AgentWolf
AgentWolf
Tyler
Seattle, WA
  • Thread starter
  • Thread Starter
  • #10
Synergy sway bar connection no longer would bolt on with the truss so we had to weld it on.
AgentWolf
AgentWolf
Tyler
Seattle, WA
  • Thread starter
  • Thread Starter
  • #11
Jeep goes in on Friday to a specialty alignment shop to get the axels straight and ensue the rest is in spec. It’s not in any shape to be driven much until that is done.
I ordered 5 37in Yokohama Geolander g003 tires that should arrive next week to get mounted up.
Don’t have a great photo but this is post lift. The 33s look tiny.
AgentWolf
AgentWolf
Tyler
Seattle, WA
  • Thread starter
  • Thread Starter
  • #12
37s are on! The door entry requires a ladder 😅
Uranus
Cassie
Ypsilanti MI
vm.tiktok.com
Nurse
37s are on! The door entry is at my waist.
Need more pictures from the side. Also, how tall are you? Seems relative.
I have 37s Mickey Thompson Baja Boss’s and a 2.5 Metal cloak lift arriving next week. Can’t wait.
AgentWolf
AgentWolf
Tyler
Seattle, WA
  • Thread starter
  • Thread Starter
  • #14
Side shot. The rear is getting heavier springs to bring it up more. I’m 5’9
Kreepin1
Kirk
Central Illinois
Those look huge! Could you measure the spare PLEASE! I'd like to know the overall diameter, tread width, and sidewall width. I don't want the height of the tire with the weight of the Jeep on them, just trying to figure out how I'm gonna stuff those monsters under my Jeep...
Morris 4x4 Center
