- CavFab
- May 9, 2018
- Wildwood ga
- 2018 jlur
- Occupation
- Aftermarket Jeep Product Manufacturer
We have been stewing on these for a while. Body mounted sliders just don't get the job done, and most of the frame mounted options out there don't look great or cant function as a step! Our HardLine Rocker Guards are manufactured form 3/16 steel plate and incorporate a unique approach to rocker guard design that allows you to remove the fully welded outer shell for cleaning, painting, or replacement if you somehow manage to damage the outer shell.
These things are absolute BEEF
20% off Introductory Pricing will end in the next few days, when it does end, our JL forum discount code will work (they are not stackable).
FEATURES
WHAT'S INCLUDED
Find Them HERE: https://cavfab.com/products/jl-rocker-guards-4-door
- Available As a Bolt on Kit / Weld on Kit / or Long Arm Suspension Compatible
- 3" step
- Made from 3/16" American Steel
- CNC Laser Cut and Formed
- Made in U.S.A.
- Ships Raw Steel
- Long Arm version requires welding on all frame mounts
- 6 Rock Slider Frame Mounts
- Driver and Passenger Rock Sliders / Rocker Guards
- Mounting Hardware for bolt on
- 3/16 Aluminum or Steel Outer Skin optional
