Mine&Hers
Elmer
2019 Jeep Wrangler unlimited Rubicon
Just installed the Cargo Dog in my Jeep JL and all i can say is it is a top of the line add on for my jeep, thanks again to MKE AT Cargo Dog for offering such a great product to all of us looking for safe secure storage in our jeeps. if you are looking for safe lockable storage and can delete the rear seat i highly suggest you look into Cargo Dog.
Here are a few pictures of the cargo dog installed
Jeep Wrangler JL Cargo Dog rear seat delete storage solution installed IMG_5033
Jeep Wrangler JL Cargo Dog rear seat delete storage solution installed IMG_5032
Jeep Wrangler JL Cargo Dog rear seat delete storage solution installed IMG_5035
Jeep Wrangler JL Cargo Dog rear seat delete storage solution installed IMG_5031
MauiSteve
Stephen Rodgers
2021 Rubicon 2 door, 2018 Colorado ZR2, 2009 Honda Ruckus, 1973 Honda CB750
Mostly retired
Nice setup.
TRMFAM
Rob
OK
Just saw this in a gladiator a few weeks ago. I like it a lot. I would be interested in your thoughts after a month if anything changed. Thanks for posting!
Mine&Hers
Elmer
I’ll update when we get back from our trip,check out Wibornz post on the cargo dog he run the prototype for Mike and if has held up to all the adventures him and his wife have been on it is as good as I can see it is.
IceBerg
SW Missouri
2021 XR 392
I have had the CargoDog installed in my Jeep for over a year now and it's been great. I did have to make some adjustments to make it fit my needs but all in all it has been great.
wanderer
Ralph
Carlsbad CA
Engineering Geologist
I just installed mine on a 24 my rubicon x the weird gap cover seens to be too big for the new gap. What did you guys do? Also i forgot to replace the bolts not used in securing the cargo dog . Will that be a problem when the weather gets wet? Finally i just plugged into one of the usb c ports But i can’t get the lights in the box to turn on am I missing something? Or is the usb-c hub bad ? Do both sides have lights ? I cant find a light on one side?
And lastly what about plugging the power into the 120 ? Volt 3 prong outlet ? Is that too much juice for the cigarette plug adaoter that comes with the cargo dog box?
Terrymo
Terry
2023 JLURXR 3.6 ET
I modified my gap cover and will take some pics later today
i would replace the bolts
i tapped into the USB port wiring at the back of the console and used a harness with a Deutsch style connector
There are led light strips on each side and there is a cable that passes from the passenger side box into thd drivers side box that needs to be plugged in
Jeep Wrangler JL Cargo Dog rear seat delete storage solution installed IMG_1660
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
I have been using a Cargo Dog for over three years. It is a fantastic product. Mike the owner is an enthusiast and great guy in general. It is by far one of the best mods that I have added to my Jeep. I secure probably a couple thousand dollars worth of gear in the Cargo Dog. It has been a flawless in operation and super easy to instal or to un install.
Terrymo
Terry
2023 JLURXR 3.6 ET
Ok here’s some pics. I added continuous loop cam buckle ratchet straps running under the boxes to lash stuff down on top if needed. If not the loose ends are rolled up and tucked into the box. Also took some Klein tools headlamps and epoxied magnets to the back and attached to the boxes. I mssed up the clips and receivers on the gap cover and ended up using nutserts and black hardware to hold the piece in plac. Also fabricated some little filler pieces to cover the open area between the gap panel and the wheel well. And fabricated two boxes from 1/4“ ABS to use the space in the rear seat footwells
Jeep Wrangler JL Cargo Dog rear seat delete storage solution installed IMG_2236
Jeep Wrangler JL Cargo Dog rear seat delete storage solution installed IMG_2237
Jeep Wrangler JL Cargo Dog rear seat delete storage solution installed IMG_2239
Jeep Wrangler JL Cargo Dog rear seat delete storage solution installed IMG_2240
Jeep Wrangler JL Cargo Dog rear seat delete storage solution installed IMG_2241
Jeep Wrangler JL Cargo Dog rear seat delete storage solution installed IMG_2238
Jeep Wrangler JL Cargo Dog rear seat delete storage solution installed IMG_2242
Jeep Wrangler JL Cargo Dog rear seat delete storage solution installed IMG_2243
wanderer
Ralph
Carlsbad CA
I did plug the cable from the 60-40 side in but still dont have power to the lightsin the box I don’t know what a duestch plug is please explain. Can you extend the 3 prong plug to be inside the cargo box ?
Mine&Hers
Elmer
Just wondering, did you turn on power switch inside center storage area switch needs to be on for lights to come on when lid is opened.
Terrymo
Terry
2023 JLURXR 3.6 ET
I made my own harness from the Cargo Dog box to the USB wiring inside the back of the center console using this style of connectors. Just so I could have the Cargo dog box hardwired but still be able to easily disconnect the power in order to take the boxes out.
https://www.amazon.com/gp/product/B07DCMTGXQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I don’t know about the three prong plug.
As @Mine&Hers suggests, check that you have the switch in the center compartment on. Check that you have power to the center console USB port. Then check the fuse for the USB port.
Then maybe a call to the manufacturer.
wanderer
Ralph
Carlsbad CA
@Terrymo Do you have any pictures of how you made the panels for the gaps ? How did you get those little alligator clips back together for the factory gap cover?
Terrymo
Terry
2023 JLURXR 3.6 ET
CAD (cardboard assisted design) and these contour gauge profile tools. I actually installed the Tuffy Security Products in floor locking lid for the rear cargo cubby so I used the factory carpeted plastic lid to make those little filler pieces. Sorry no pics, but here’s the contour gauge profile tool to copy the curvature.
https://www.amazon.com/gp/product/B083PSVB6X/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
I bought several different aftermarket clips trying to get that gap filler panel to sit flat but it was still bowed a little in the middle. I ended up putting 3 nutserts in the sheet metal under the gap filler panel and using black stainless 1/4-20 hardware to bolt it down. Here’s the clips I used. I think I tried and couple of different ones that were close but not exact
https://www.amazon.com/gp/product/B0B4B99BV8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
