Fabtech Motorsports
CA
Jeeps, trucks, Broncos
TL/DR
Covers 2018-2024
Corner specific Dual-rate coils
Comes with Draglink Flip
Pair with the Dirt Logic shock of your preference
Include our massive Fabtech 5 Ton Joints® with a lifetime warranty.
This Trail system provides enhanced suspension performance to address all variants of off highway travel use including rock crawling, aggressive trail use and overland expeditions. On road, the suspension has been tuned with proper dual rate coil springs and shock valving to provide a very compliant ride that you will appreciate.
The system is a complete short arm suspension that utilizes the factory control arm mounts for an easy installation. The Fabtech heavy duty link arms are constructed of 1.75&quot OD. .250" thick wall steel tubing that are guaranteed never to bend. They come with large poly urethane bushings on one end with internal threads on the other to accept the ground breaking Fabtech 5 Ton Joint® for longevity and a quiet ride.
Fabtech’s long travel Dual Rate coil Springs are corner specific to the JL. This keeps the vehicle level side to side and allows for increased suspension travel. The first stage of the spring provides a soft ride with the ability to extend for additional travel. The second stage is designed to handle the payload of the vehicle and address large impact absorption at higher speeds.
To address the steering geometry with the increased ride height, a Draglink Flip System along with a heavy duty Track Bar bracket is included. This relocates the steering geometry to the factory plane allowing for full articulation without binding the draglink ends in extreme conditions.
https://fabtechmotorsports.com/product/3-trail-system-w-dirt-logic-2-25-shocks-k4117dl/
Remorseless
NC
Fabtech Motorsports
Fabtech Motorsports
CA
Correct, along with the included dragline flip to keep steering all good.
So we’d be using the factory front track bar with this setup?
Here is a less expensive option with our Stealth shocks.
3-trail-system-w-stealth-shocks-k4117m
And here is a much more expensive option with coilovers, and remote reservoirs
https://fabtechmotorsports.com/prod...ers-rear-dirt-logic-2-25-resi-shocks-k4230dl/
Just thought it would be included in this $3,200 kit.
Hucke_250
Ohio
2018 Unlimited Sport
Will you be selling the drag link flip system and bracket separately?
DubaiMarauder
Alex
Fort Worth, TX.
2023 Wrangler Rubicon Unlimited EcoDiesel FarOut
Truck Driver
TL/DR
Covers 2018-2024
Are those 35s or 37s on that rig?
Fabtech Motorsports
Fabtech Motorsports
CA
37" tires with our flat fenders.
Working on a forum discount code now, may take a bit. But will have it ready to share!
Dare I inquire about a forum discount? I’m currently shopping lifts for the new Jeep.
Not at this time, but will share this info with my Product Manager.
