- Mr. Black
- Jul 14, 2018
- Denver
- quakeled.com
- JK, JL
- Occupation
- Sweat Shop Manger, Slum Lord and Break Dancer
MODEL NUMBER: QMT1445
Link: Jeep Rubicon Hood Vent 25 Watt LED Lighting Kit - Dual Colors β Amber Markers - White/Yellow Beam (quakeled.com)
MSRP: $299.98
Enhance the hood of your Rubicon Jeep Gladiator or Wrangler JL and
Light Up The Darkness with Quake LEDs Functional Hood Vent LED
Lighting Kit!
This easy-to-install, fully functional vented LED Hood Scoops provide a
wide, high intensity Dual Color LED flood beam that mounts onto the
Rubicon Jeep hood, replacing the existing non-functional Jeep hood
vents!
Two 2.5 inch 25 Watt LED lights with 2400 Lumen per side, generate a
wide yet powerful sharp cut off flood beam to provide enhanced visibility
in complete darkness. Choose between the White or Amber beam to
tackle any unruly weather conditions. Four Amber Markers add style and
help increase your vehicleβs visibility. Choose whether you want the
Amber Markers as full time DRL or as Turn Signals.
This complete kit comes with two LED Hood Scoops, all LED lighting,
main fused & mesh loomed wiring harness, plug and play marker
adaptor and gaskets to protect the hood surface. These scoops are
powder coated with our toughest texture black finish.
Features:
β Constructed of steel, finished with black powder coating
β Dual Color White and Amber LED Beam Options
β Flood beam pattern enhances visibility in inclement weather or darkness
β Mesh Loomed Wiring harness includes all connectors,
β Plug and Play amber marker adaptor allows you to choose amber DRL or amber turn signal function
β Raw lumens: 2400 per side
β Power output: 25W per LED light
β Dust and moisture resistant lens
β Allows hot air to escape from the engine bay
β Gaskets to protect paint surface
β 3 Color Quake LED Metal Logos
β Bolt-on installation - no drilling required
Specifications:
β Light Source: 25-Watt High Powered LEDβs
β Light Color Temperature: Dual White / Amber
β Light Pattern: Flood
β Function: Amber Marker or Turn and High Output Dual Beam
β Mount: Bolt-On to OEM Rubicon Hood Vent
β Lighting Voltage: 10-30VDC
β Wire Harness Voltage: 12VDC
β Wire Type: Easy Harness β Mesh Loom
β Wattage: 25 Watts Per Side
β Amp Draw: 2 Amp Draw at 12V
β Raw Lumens: 2400 Lumens
β Ingress Rating: IP67
β Laser Cut, CNC Bent Steel Mounting Brackets
β Black Powder Coating
β Dimensions 16.5 x 7 x 2.75β (LxWxH Inch)
β Product Weight: 9lbs
β LED Life Expectancy: 50,000 Hours
β Operating Temp Range: -40Β°F to +140Β°F (-40Β°C to +65Β°C)
INSTALLATION NOTES
Installation Difficulty: Easy
Installation Time: 1-2 hours
Model Number QMT1445
β Fits: 2018-24 Jeep Wrangler JL & Gladiator JT Rubicon
β Excludes: JL Wrangler Sport, Sport S & Sahara) and Excludes
Gladiator 2020 (Sport, Sport S, Overland, North Edition)
WARRANTY
β 1 Year Limited Warranty
INCLUDES:
β 2.5β Dual Color LED Lights β 2pcs
β Vented Hood Scoops with bottom mounts β Left and Right (2pcs)
β Amber Markers - 4pcs
β Main Wiring Harness β 1pc
β Plug and Play Amber Marker Adaptor β 1pc
β Gaskets β 2pcs
β Hardware Pack
β Zip Ties β 8pcs
β Cable Holders β 10pcs
β Allen Wrench
β Instructions
BUY IT HERE: Jeep Rubicon Hood Vent 25 Watt LED Lighting Kit - Dual Colors β Amber Markers - White/Yellow Beam (quakeled.com)
MSRP: $299.98
Lighting Kit!
vents!
Features:
Specifications:
INSTALLATION NOTES
WARRANTY
INCLUDES:
β Gaskets β 2pcs
β Hardware Pack
β Zip Ties β 8pcs
β Allen Wrench
β Instructions
