FORDGURU
chris
riverside ca
2021 JLURD
Decided to post up
started a build recently for my wife
21 Rubi diesel
went with
3.5” rock jock pro kit
fox elite 2.5
fox bump stops front and rear
RJ track bars and correct link steering
RJ antirock rear sway bar
artec inner c gussetts
a few few pics so far
Jeep Wrangler JL My JLURD build 3.5 Rockjock 38’s IMG_1989
Jeep Wrangler JL My JLURD build 3.5 Rockjock 38’s IMG_1991
Jeep Wrangler JL My JLURD build 3.5 Rockjock 38’s IMG_2007
Jeep Wrangler JL My JLURD build 3.5 Rockjock 38’s IMG_2020
Jeep Wrangler JL My JLURD build 3.5 Rockjock 38’s IMG_2046
Jeep Wrangler JL My JLURD build 3.5 Rockjock 38’s IMG_2024
RudeJeepin
Carl
Washington
2021 JLURD
Looking good.
Any chance of a better pictures of the rear fox bump stops? Seen plenty of the front, but not of the rear. Thanks.
CO2Wrangler
21 JLURD
Let us know how the ride is. Those springs look quite a bit more spaced out than my Clayton kit but curious the difference.
DevilDogJeeper
Shane
Austin
2021 JLURD
I have a 21 JLURD as well and have been eyeballing that same shock/bump set up from Accutune. Looking forward to hearing your thoughts on that set up.
Rubenmora1
Ruben
Ontario CA
2023 jeep JLUR
Any chance you could measure the distance in the springs ? And from where you measured? I’m on a 3.5 RK lift but idk if my rear is sagging or that’s how it’s supposed to be. I lost my stock measurements so idk where I’m at rn. If it’s sagging I’m gonna bump the rears to 4.5 springs triple rate from RK.
FORDGURU
FORDGURU
chris
riverside ca
2021 JLURD
Sure where do you want me to measure
