Archie PJ
In the last month or two, I've noticed a strange "wind" noise. I was wondering if anyone else has experienced this and determined its source.
The noise may occur at 60-70 mph. It often sounds like it is coming from the driver side near the windshield/roof/ rain gutter. The sound is similar to what you might get with plastic scraping/vibrating. The first time it happened, I actually pulled over and inspected underneath to see if I had picked up some plastic or if something was loose. After time, it seemed more like it was coming from the windshield/roof/door frame area. It is not continuous. At times, I can make it do it by turning the steering wheel slightly right, at above speeds. When not making the noise consistently, it will also occur when hitting those little "dips" in the highways. This would seem to indicate that the air is causing it when the Jeep "flexes" going over these little dips. My possible causes: 1. The air getting in near the windshield/door frame/roof interface, more when the Jeep "flexes." 2. Wind gets into the roof/roof panel joint, more so when the Jeep flexes.
Anyone had something similar? Thanks.
