Winch power hook up question
Sanchese
Carlos
Toronto, Canada
2021Rubicon, 2022 Rubicon Xtreme Recon on Order
I have a warn winch zeon 12S.
My question is how should i install it to the battery?
Should i use a switch or one of the Aux switches in my jeep?
Is a solenoid needed? or just straight hook up to battery?
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
Install it directly to the battery with a solenoid on the Red(+) lead close to the battery. Control the solenoid with a low power Aux switch (I use Aux 4).
There are other ways to install it which will work but using a solenoid allows you to keep the winch unpowered until you need it. Much less likely to get a short in a front-end collision or when fording water.
https://www.amazon.com/dp/B000CQFVN8
