Why Do I Keep Buying the Wrong Headlight Bulbs?
AUXITO
Summit Sponsor (Level 3)
AUXITO
2020 Jeep Wrangler
Perhaps you’re tired of the dim light from your original halogen bulbs, or maybe they’ve reached the end of their lifespan and are getting dimmer by the day. In this situation, you’re probably eager to replace them with new bulbs to avoid hitting something while driving at night. But in such a rush, buying the wrong product will only make you more anxious.
So, what exactly causes you to make the wrong choice?
Reason 1: Incorrect Information Sources.
As a beginner, you might not know where to start. You might rely on a friend’s recommendation, look up “universal models” online, or trust a seller’s unprofessional description—without checking your vehicle’s manual or an authoritative database.
Reason 2: Uncertainty About Bulb Models
There are numerous socket types for automotive headlight bulbs, such as H1, H4, H7, H11, 9005, 9006, and so on. These can vary by vehicle model, year, and even configuration (e.g., halogen vs. xenon). If you don’t verify your vehicle’s original specifications, simply buying a “universal LED” bulb will likely lead to a mismatch.
Reason 3: Failure to correctly identify which bulb needs replacing
Not distinguishing between the different bulbs inside the “headlight” assembly. A single headlight assembly may contain low beams, high beams, parking lights, and turn signals. You might intend to replace the low beam but end up buying a high beam model.
Reason 4: The replacement bulb doesn’t fit properly
This is especially true regarding dust covers and installation space. When upgrading to brighter LED bulbs, some manufacturers design their products with oversized cooling fans or excessively long heat sinks at the rear, making them impossible to install in tight spaces. Additionally, whether the mounting bracket is precisely designed to match the dimensions of the original halogen bulb is crucial for a successful installation.
So, what kind of issues have you encountered?
r_j_dill
Robert
2020 JLU RUBICON
So what would be the correct LED bulb to replace the factory halogen bulb?Plug and play
r_j_dill
Robert
2020 JLU RUBICON
Looking to replace the headlight bulb on a 2025 sport
AUXITO
AUXITO
AUXITO
2020 Jeep Wrangler
The headlight bulb model for the 2025 Sport is H13. You can choose an LED bulb of this model as a replacement. Please check the product page to see if it is labeled as “CANbus Ready.”
