Rhinebeck01
- May 9, 2018
- Ormond Beach, Florida
- '18 JL Rubi, '26 Cybertruck, '01 Harley FatBoy
- Occupation
- Retired at 55 ..
@MaverickIt would be a fine system if the battery wasn't a junk battery in a crap location. NEVER should they have put a battery Under the Fuse box that you have a high chance of damaging a connection when pulling the system apart or putting it back together.. I run my jeep on a tender for both batteries, Doesnt matter if i drive it or not. its on the charger so i dont have the issues of the trash battery going out once a year. if you want piece of mind and the ability to change the battery If it goes dead then the dual full battery system is the way to go plan and simple. My Pick up thats 40+ years old has had the same battery for 8 years now... its gets drive once every two weeks...... still doing better then my JLU batteries
Not sure if you know this, but pulling the PDC is not the recommended or suggested way to get to the Aux battery.. Actually, the worst way to do it.
Sure would be nice if the Aux was right in the engine compartment ..... but it can be easily accessed by peeling back the fender flare liner which is how FCA tells the Techs to do it.. An even easier way that takes less then say 15 min. is to just pull the fender flare.. Neither approach is chancey.. risk of damage, etc... other then a few rivets or a fender liner clip(s).
Anyway, just wanted to clarify that it is not suggested / recommended to go pull the PDC to do the job.
IF a guy just has a clue lets say, the stock dual battery system is not that difficult to understand / to deal/live with... and of course..... you can always, replace the OEM battery(s) with aftermarket offerings that are beefier/better.
