Where do I find these
Rubycon50
Royce
Glendora, California
2018 Jeep Rubicon JL
These are the little zip ties that go around your electrical cable and then plug into your frame. On amazon I can buy the single version of this which is called a fir tree zip tie but I can’t seem to find the double wide version like this. Has anybody else found them?
Jeep Wrangler JL Where do I find these 41A5118A-1E32-40D6-A26B-5FA3AECA4D0E
roaniecowpony
Retired Engineer
The parts guy at your local dealer can usually find this kind of stuff. Sometimes this stuff is pretty cheap and sometimes it floors you. I found the fender flare retainers at the dealer for a reasonable price.
These are stated as being to fit 1/4" hole.
https://www.thefastenerwarehouse.com/Electrical/EL112.html
Another source.
https://www.clipsandfasteners.com/Cable-Ties-Mounts-s/59.htma
If you google "cable tie push mount" you'll get a lot of leads. If the hole in the body is about 1/4", you should be able to find a workable cable tie at a NAPA, Autozone or O'Reilley. If you want the exact OEM part, good luck.
cOtter
Southern, Indiana
‘20 Sahara 2.0L Ocean Blue Metallic, Toyota Highlander & Pontiac G6 coupe
Senior Manager PM (Automotive OEM)
Sometimes you can find them as Christmas tree clips as well
