blnewt
- Brad
- Oct 8, 2018
- New Mexico
- 2019 Jeep JL V6 SportS, (Retired 74 CJ-5, 80 CJ-7)
- Occupation
- Just ask @cosine he knows!
Never used Jeep spacers but have used spacers on road cars, never used any loctite, and AFAIK it was never recommended to do so.I have never and would never use any thread locker on wheel spacers. And certainly not red. I think it’s included or recommended as a CYA for the lowest common denominator end-user who will never check the torque or inspect their stuff, and who will go a long time before rotating the tires or taking the wheels off for any reason.
Having a nut go loose on a spacer is not any more likely or unlikely than having a nut go loose on a wheel. The only difference is you can’t see or otherwise easily check if a nut is loose on a spacer. So follow proper procedures and stay on top of maintenance. Retorque and inspect the spacers after the first 50-100 miles and every tire rotation after that.
Once I started reading about Jeep (and I assume other 4x4 applications) there was a lot of talk about using thread locker, maybe it's more common in these vehicles, but I agree 100% with @scrape , proper inspection/confirmation of torque at the time/mileage mentioned above is the way I've always done it, and FWIW never had to re-torque any spacer nuts, always held torque from day 1.
The only thing that sucked w/ the spacers I used was the soft metal nuts used w/ the spacers, very easy to round off if you didn't have your socket 100% flush and it must be a 6pt.
