Wheel shaking at highway speed when braking
cthomas31
Caleb
Ohio
2024 JLU Sport S Manual Soft top
Hi All,
There is probably already a post about this topic, but I couldn’t find it from a simple google search. So here’s my issue.
I have a 2018 JLU Sport with a 2.5” lift running 35s.
I just hit 45k miles and started to notice my wheel shaking whenever I’m braking at highway speeds. Is this an indication that I need new brakes and rotors already?
I just did an oil change and tire rotation at 45k and the brakes looked fine. So the only other thing I can think is that the rotors are bad or the tires are out of balance.
Any help is much appreciated!
Joe20
Chicago
2022 JLU Sport
Very high chance the rotors are warped. They can be resurfaced if they have enough thickness tolerance, otherwise replace. This issue can be caused by improperly torqued lug nuts on aluminum wheels, but it can also just happen. It’s not wheel balance — that would occur at all times at highway speeds, not only while braking.
Red Willy
Jim
SW Florida
2026 2 dr. Willys XR
Professional Nobody
Since you're running 35s and are probably going to replace the rotors, I'd opt for HD brake replacement.
Recce
Jay
Ontario
2022 JL Willys
I had the same problem in my Saturn SC years ago. Thought it was the rotors but turned out to be tie rod ends.
*Edit - In my experience, rotor issues tend have a pulsating feel rather than a vibration/shake.
AlgUSF
Melbourne, FL
2021 JLUS, 2014 Tundra, 2013 Odyssey, 2002 Civic
I agree on the opinion that it is most likely warped (front) rotors and I'm doing a set on my Tundra today. I've heard the "improperly torqued" argument for a while, but I'm not overly certain "how" improperly torqued wheels will warp a rotor as they are torqued to the hub behind them which is hardened steel and most likely extremely true.
Maverick909
I.E.
www.instagram.com
Id guess rotors my self. If you pay shipping cost i have a full set with 8K miles on them sitting in my garage calipers and pads too maybe some beer money with it LOL
OrneryBear
Charles
Central OH
23 Sarge JLUR 6spd
brakes "looked" fine but did you check inside versus outside pad wear? In my experience this issue is typical of a stuck caliper that isn't floating properly.
speedymart
mephis
2021 jl
Steering wheel shaking while braking points to your front rotors being warped. Replace them and move on. 45k is pretty good for the factory brakes.
