Bubby Banana Bonez
As a brand new owner of a 94’ YJ, what should I know that you wish you would’ve known when you got your first Wrangler?
Oh awesome - thank you, I’ll check that out! I appreciate your response, and yeah, it’s encouraging to know that 94 is generally a good year. I bought it because it has little to no rust at all. Kept in the garage, and is stock without modification.First thing to expect is that this forum focuses on the JL, which is 2018 and newer Wranglers. While some people here know about YJs, you may not get as much useful feedback here. There is a YJ section over at https://www.wranglerforum.com/forums/ that will have some more knowledgeable people in one place.
Second thing to expect is that a 30 year old Jeep potentially has a lot of issues. Depends on how well it was cared for. It may be in good shape or it may be a basket case.
Is it mostly stock or modified? 4 or 6 cylinder? Or something else swapped in? Stock axles or upgraded? How many miles on the clock?
The 94 is a good year for a Wrangler but it's hard to know on a vehicle that old.
Oh, and post pictures if you can. ?
Leaf springs are less likely to death wobble than coil/link setup on the TJ and newer (1996+) but it's not unheard of. New spring bushings can tighten it up a bit, assuming that the original bushings haven't been replaced yet. Ball joints and steering ends (tie rod and drag link) can contribute to wobble. Replace if they're worn.Oh awesome - thank you, I’ll check that out! I appreciate your response, and yeah, it’s encouraging to know that 94 is generally a good year. I bought it because it has little to no rust at all. Kept in the garage, and is stock without modification.
I was concerned about buying something so old, so I was weary of any rust or any symptoms of the dreaded death wobble.
I had just learned about Fluid Filmto prevent and protect from rust… was just wondering if there was anything else y’all think I should know.
Thanks again for the further insight and I’ll check that group out ????
