Upper control arm clearance issue
70sKid
SF Bay Area
'03S2000 '03Tacoma '08E90M3 '21JLUR392 (ordered)
I’m wondering if anyone can tell from these pictures if my front suspension is off center or if I have 2 left control arms. Note the spacing difference between the upper control arms and the frame. Specifically, the right side is touching the frame while the left has more clearance. I’m assuming it’s an off center thing, but figured I’d see what those with more experience think.
Jeep Wrangler JL Upper control arm clearance issue IMG_6186
Jeep Wrangler JL Upper control arm clearance issue IMG_6185
Hucke_250
Ohio
2018 Unlimited Sport
It’s hard to be 100% certain that you have 2 left upper control arms from the pictures. I would measure that the front axle is centered left to right and report back. Is this stock or aftermarket suspension components? The upper control arms appear to be stock.
70sKid
70sKid
SF Bay Area
Thanks! This is a stock setup. I’ll see about measuring for how centered the front axle is.
Reinen
2021 Jeep Wrangler JL Rubicon
It's really easy. Just drop a weighted string over the fenders. It should hit both passenger & driver tires in the exact same location. If they're different it's because the Track Bar isn't the right length. You can figure out how much each tire is shifted.
70sKid
70sKid
SF Bay Area
