Up Your Diesel Exhaust Knowledge
CJ SCION
Tim
Michigan
2024 JLU Willys
Tired Again
If you haven't seen this video, have a look.
Hard Rock Jeep
Richard
Nashville
2016 JKUR HR, 2022 JLUR 2.0, 2022 JLUR Diesel
Thank you for the link. Very informative. Explains diesel exhaust systems quite well.
CJ SCION
CJ SCION
Tim
Michigan
2024 JLU Willys
Tired Again
You are welcome. The cross sectioning of the DPF was much appreciated here. I have monitored the DPF pressure delta for over 4,000 miles and rarely see it over one psi, when mashing the pedal it will rise a bit under boost. My driving habits with the 3.0 always give time to run warm, thus burning away the junk gasses. I use the JK for short trips.
On side notes, I have added just 2-1/2 gallons of DEF since taking delivery. Nearing the 5,000 mark and still have just under 1/2 on the gauge. For whatever reasons, the MPG's have really picked up this spring. Currently at 29.8. Could be just the break-in or a little help from hot dry weather.
Deleted User 38384
...the MPG's have really picked up this spring. Currently at 29.8
What state do you live in, do you do lots of highway driving, and what's your average speed?
Also are you going off of what the Jeep is telling you you're getting or are you calculating it yourself at the pump?
I seem to be averaging 23 mpg lately.
CJ SCION
CJ SCION
Tim
Michigan
2024 JLU Willys
Tired Again
Michigan, about 30% highway with 65 mph max. Currently the dash indicates 30.2 and may still climb, you can see the snip of the fuel spreadsheet. Sad to here of your 23 mpg.
This is a stock vehicle with an elderly driver who is rarely in a rush. The following is the fuel history.
Jeep Wrangler JL Up Your Diesel Exhaust Knowledge Screenshot 2023-06-29 220705
Deleted User 38384
Interesting. I did a test a while back to see what I could get if I drove like an old man. On one fuel tank, I was able to get 33.45 MPG. I kept it at a max of 55 mph and never smashed the pedal.
Don't get me wrong, I'm still beating the build sheet MPGs by 1.4 MPG.
I was kind of hoping closer to 35mpg but I understand there's a lot of fudge factor in the trip timer. It's definitely the best MPG I've achieved so far. Should be interesting to see how this changes once I'm running 35s and not dumping soot back into my engine anymore. Maybe another attempt in the fall... ?‍♂
Love thee Excel spreadsheet. Keep it up man. Love to see what you end up getting in the long run!
