Tapping into factory subwoofer?
Kmicucci
Kevin
NH
2024 JL Rubicon
Has anyone tapped into the wiring for the factory sub to get an audio signal (RCA’s) for an aftermarket amp? I tapped into the soundbar wiring on my 2019 2 door JL. I am hoping to skip a step in my new 2024 JLU and use the factory sub wiring. I did some searching but only found people tapping into the soundbar wiring.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Unless it's changed, ANC and crossover/amplification all happens at the Alpine amp. There willl not be any low level audio (RCA) at the sub, just high level (speaker level).
I believe it's crossed over very low, so you may not have the upward extension you are looking for on that signal.
Kmicucci
Kmicucci
Kevin
NH
2024 JL Rubicon
OK so the only thing I would have to gain by tapping into the subwoofer wiring is a shorter run of RCA’s VS tapping into the soundbar wiring. Sounds like I’ll be going the same route I went with on my last setup. Thanks for the info.
Blues Fan 30
St. Louis
Imo the worst part of the whole sound system. The sub is basically non existent.
