ScotM
- Scot
- Jan 3, 2023
- Southern California
- 2022 Jeep Willy's JL 2 Door
Nice, that’s a much shorter route. I’m currently working on making sure I have continuity between everything. My antenna mounting plate was anodized, so I’ve sanded that down , the I’ll attach the grounding strap to the plate, then run it to that closer ground. I appreciate the help.This is where I am running a ground wire to the chassis from the rear. It is run underneath the rear tailgate rubber seal. You can use any bolt underneath to terminate the ground wire.
