SWR help
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
I installed a midland 275, with the magnetic antenna mount and the 32” MXTA26. I’m using an swr meter and getting 1.74 reading. No matter where I put the antenna- on the ground, on the ground on a steel plate, on the Jeep. Etc. I’m using the sw33 surecom meter, cause I had that available. If I put the antenna on my epoxy floor, not grounded, I get a 1.96 swr. It has a 20 ft cord, all measuring was done without it being coiled. Anyone else measure their swr and find it higher than ideal? Not sure what to do next, since midland says the antenna is optimized for the mxt275. Maybe my meter is not the best? Thoughts and advice would be appreciated.
Jeep Wrangler JL SWR help IMG_6235
Jeep Wrangler JL SWR help IMG_6236
Jeep Wrangler JL SWR help IMG_6237
Pape
Quebec
JLU Sahara
What channel did you test the swr ?
Under 2 is acceptable in my book.
Usually you test at 1 and 40 will tell you if the antenna is to long ot two short, tahn on your main frequency.
Still Jeepin
Gary
Oregon
2022 Wrangler JLU Rubicon, 1983 CJ7
Firefighter/Paramedic Retired
There are couple things to try. Check swr on channel 1 and then 22. Compare the numbers. If it’s higher on 22 the antenna needs to be longer. And opposite for higher on ch 1 shorter. There’s some adjustment you can adjust with the set screw on the on the spring.
I installed one a while back and ended up trimming about a 1/2” of to get a decent swr.
Good luck, Gary
ScotM
ScotM
Scot
Southern California
I checked on Chanel 18
Terrymo
Terry
2023 JLURXR 3.6 ET
@Nokones
@THAW
Did you also test in an open area away from any obstructions and get the same results?
Here’s a good thread in case you didn’t already see it including someone of my fumbling around pretending to be a radio dork.
Terrymo
Terry
2023 JLURXR 3.6 ET
I don’t think that Midland antenna is tunable? I see mixed answers from Midland on ground plane regarding that antenna. One answer says not required another saying it would be best. Also in my limited but possibly wrong information anything under 2.0 is fine for normal trail use,
ScotM
ScotM
Scot
Southern California
Good luck, Gary
Thanks I”ll do that this afternoon
ScotM
ScotM
Scot
Southern California
I don’t thist Midland antenna id tunable? I see mixed answers from Midland on ground plane regarding that antenna. One answer says not required another saying it would be best. Also in my limited but possibly wrong information anything under 2.0 is fine for normal trail use,
I’ll try the set screws first and see if I can shorten it up. I checked outdoors, but I live around hills. I”ll try it at the top of my hill, nothing but clear views up there.
2nd 392
Ca
@Nokones
@THAW
Open area with the doors closed too.
ScotM
ScotM
Scot
Southern California
THAW
Foster
23 JL4DrRubicon
Experiment with positioning the antenna to create an optimal ground plane. What did the steel plate setup look like?
At 1.76:1 you're transmitting about 92% of your radio power. So not bad, and the reflected power is low enough it won't hurt the radio.
ScotM
ScotM
Scot
Southern California
I’m mounting the antennas on the back of the Jeep, and going to run the ground strap with the antenna cable and use the ground in the passenger wheel well. It just seems cleaner than trying to drag the grounding strap under the vehicle to the chassis.. thoughts on that?
Nokones
Kenny
Sun City West, AZ
This is where I am running a ground wire to the chassis from the rear. It is run underneath the rear tailgate rubber seal. You can use any bolt underneath to terminate the ground wire.
Jeep Wrangler JL SWR help 20260305_114019
Jeep Wrangler JL SWR help 20260305_113640
