- Oct 7, 2019
- Metairie, LA
- Website
- www.oraclelights.com
- 2019 Jeep Wrangler JL
- Occupation
- Automotive LED Manufacturing
Want to add halos without opening your Jeep's headlights? We offer a surface-mount version that eliminates the tricky install and makes it much easier for a DIY project.
Get an eye-catching customized headlight styling with a simple, easy install! The ORACLE Lighting halo kit for a Jeep Wrangler JL features our expertly-crafted surface-mount waterproof design and our optional ColorSHIFT® technology for brilliant colors with the best quality LED components. Encased in a special polymer resin, our surface mount halos are completely waterproof (meaning they can function properly even when submerged underwater), and they easily install by attaching directly to the exterior of the headlight lens using a patent-pending system. This simple process cuts down installation time from hours to just minutes!
No baking the lights, no cutting the lights!
While some vendors cut corners, we use advanced LED chips that produce an impressively bright output while consuming less power. Choose from single-color for simplicity or RGB for variety. Easily control the halos with one of our easy-to-use controllers, and consider the popular ColorSHIFT®, which gives the user RGB control thanks to the 5050 tri-node LEDs that allows you to select any color imaginable. Using the latest lighting technology, our cutting-edge halo kits for cars are a great way to personalize your ride with show-stopping looks and industry-leading performance. Stand out from the look-alikes with an ORACLE Lighting halo kit!
Features:
• Bright output with less power consumption
• IP67 waterproof surface-mount technology for easier installation to the lens
• Customized look with even more personalization with ColorSHIFT®
• 1 year warranty
Specifications:
• Warranty period covers the LED and driver components. Hard part decay due to UV damage, oxidation, or environmental conditions are not covered under this stated period.
• White and amber are street-legal colors. Other colors not intended for on-road use; please verify your state and local driving laws.
Kit includes the following:
• (2) ORACLE Surface Mount Waterproof Headlight Halo Rings
• (2) Quick Connect Wiring Adapters
• (2) Wide Voltage External LED Drivers
• FREE Adhesion Promoter Pad (Part #2082-504)
Get yours here!
Features:
• 1 year warranty
Specifications:
Get yours here!
