Spacer Lift Question
Kleiss1
Gary
Arizona
2021 JLURD 2018 Mustang GT 6-sp.
Is the labor to install spacers about the same as going with a short/2” lift? I’m assuming you need to remove the same stuff to install. Thanks
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
Some kits replace more components than others which will impact labor required. But adding a spacer to an existing spring and replacing with a longer spring is the same amount of labor.
Kleiss1
Kleiss1
Gary
Arizona
Why couldn’t you raise up by the frame and use a spring compressor to collapse the spring and slip the spacer on the top?
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
The bumpstop tube in the front requires the removal of the front springs in order to place the spacers above them.
