SoCal MOPAR Lift Kit Installer
Hinxster
Redondo Beach, CA
2018 Rubicon JL
Hello - I'm looking for a reputable shop in Southern California for the installation of a Mopar lift kit on my 2018 JLUR. All recommendations are appreciated!
Maverick909
I.E.
www.instagram.com
Honestly it’s so simple. You can do it in the driveway! If not most dealers are pretty inexpensive for the install. If not I had my 76 gmc truck re-geared at brothers 4x4 in Montclair. Seem to be fair priced and did good work.
BIGW0RM
Orange County, CA
23 Raptor // 22 M3 Comp X // 20 RRS
Try 88 rotors. They do good work and don't cost and arm and a leg for installs.
Djhyper66
JOHN
Corona Ca.
Jeep Wrangler 2020 JL
Before you get the mopar kit installed .. buy front and rear track bars and front correction pad for the springs … and since your spending money mind as well add a new steering stablizer .. I went bother 4x4 in Montclair , they got me the kit for 1100 dollar .. and bunch of other parts for a good deal as well .
Hinxster
Redondo Beach, CA
2018 Rubicon JL
I understand why the new stabilizer may be needed, but what's the benefit of the new track bars and correction pad?
Djhyper66
JOHN
Corona Ca.
When you lift your jeep the higher it goes the axles start turning and going crooked , cause the stock track bar doesn’t extend long enough … that one reason why mopar lift kits the springs bow to the side . The jeep slightly crooked .
when you lift the jeep you should be able to measure from a tape measure from the outside fender to the spring and it should be the same length on both sides ..if you don’t get a track bar the measurement on one side might be 1 inch more then the other .
Tons of people install a mopar kit with out track bars but if your doing all that work … mind as well add the extra step ..
also everyone recommends the rock krawler front spring pads over the mopar ones … helps prevent the bowing .
Hinxster
Redondo Beach, CA
2018 Rubicon JL
Got it! Thanks for the explanation.
kah.mun.rah
Merenkahre Jr.
Duat
The reason I added an adjustable track bar to my Mopar lift:
The reason I added correction pads to my Mopar lift:
