Jeremynolan94
Hi all,
I had the ACT JP6 Pro-Mass clutch installed last week, and since then my clutch has developed a pretty terribly creaking sound and feeling (see this link to a video I took that is too large to upload to the site). It's not very discernible when the car is cold, but is extremely noticeable when the car is warmed up, as it was when I recorded the video above.
I suspected it might be the slave cylinder, so I took it in to have it checked. The mechanic said that this is likely the cause of the sound and creaking feeling, and that he heard it when he placed a stethoscope on the slave as a tech pushed on the clutch. He thought that the stock slave cylinder might be overburdened by the heavier clutch setup, and recommended getting an aftermarket replacement since the stock unit is plastic. Do you have any particular suggestions for units to go with? I was looking at Centerforce but am not sure how different it is from the stock unit.
Other than this creaking issue the clutch has been a fantastic upgrade. The car feels more torquey and is much harder to stall.
