Set OEM LEDs always ON (Except Headlights) in AUTO
Sierra
Sierra
Gilbert, AZ
2023 Rubicon 4XE, 2023 Tesla M3
eCommerce Developer
Is there any way to drive in daylight with OEM LEDs always on? in AUTO
  • Headlights Halo
  • Foglights
  • Taillights
I tried with TAZERJL Mini without success.
I found the only way is to switch manually to "parking lights mode"
Jeep Wrangler JL Set OEM LEDs always ON (Except Headlights) in AUTO 1619741930740
Luxory Mode ?
Jeep Wrangler JL Set OEM LEDs always ON (Except Headlights) in AUTO 1619742121297
Jeep Wrangler JL Set OEM LEDs always ON (Except Headlights) in AUTO 1619742360108
Any idea?
Thanks! ✌
dapipp
NW Idaho
2006 TJ, 2006 LJ, 2019 JLR, 2024 JLUR
I can get you there 2/3 of the way. The problem is no halo's, just fog lights, tail lights and headlights.
Sorry, no pictures, did it a couple of years ago.
You need to go to the dealer and order the dash piece circled for a Jeep Sport. Pop the similar piece out of your dash. It will have a light sensor built into it. Put a plastic bag over the the piece and the wiring and then wrap the whole wad with some type of dark tape that will not dry out and fall off over time. I used a black silicone tape designed for repairing leaky things. Now shove that wad down into your dash and put the new part from the dealer (no sensor) in place.
Now set your switch to auto and all your lights will always be on because the wad inside the dash thinks it is pitch black outside.
Jeep Wrangler JL Set OEM LEDs always ON (Except Headlights) in AUTO dash
Sierra
Sierra
Sierra
Gilbert, AZ
eCommerce Developer
You need to go to the dealer and order the dash piece circled for a Jeep Sport. Pop the similar piece out of your dash. It will have a light sensor built into it. Put a plastic bag over the the piece and the wiring and then wrap the whole wad with some type of dark tape that will not dry out and fall off over time. I used a black silicone tape designed for repairing leaky things. Not shove that wad down into your dash and put the new part fro the dealer (no sensor) in place.
Not set your switch to auto and all your light will always be on because the wad inside the dash thinks it is pitch black outside.
Great idea! but, If I do this. I'll stuck with headlights ON, I just want the halo, fogs and taillights. I think I need to find those wiring and wire a + cable from my AUX switches so I can keep on as soon I turn on car, and at night I'll turn on headlights and dim my dash.
Now, the thing. Find those cables... lol
unsavory
Jimmy
2022 JLUR XR 2.0T Auto, 2019 JLUR V6 Manual (sold)
It's a long shot, but did you ever figure out a way to accomplish what you wanted? I would also like to do this same thing you described, without having to remember to turn the knob to the parking lights position.
So default to parking lights position with the selector in Auto, and then have the headlights come on instead of the halos at night.
  • Like
Reactions: AFD
Sierra
Sierra
Sierra
Gilbert, AZ
eCommerce Developer
Still nothing ?
A task for @tazerjl
Jeep Wrangler JL Set OEM LEDs always ON (Except Headlights) in AUTO 1674593959450
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Still nothing ?
A task for @tazerjl
Nothing I really need a Tazer for yet, but I think I'd buy one if it actually solved that one problem.
Logically, it doesn't seem too complex. Just changing the 'auto' behavior from headlights on > off to on > parking lights, which is how it should be from the factory imo.
Chip
Tom
Colorado Springs
sites.google.com
2022 JLUR XR
Isn't this an option in the Tazer JL "fog light dropout" live menu selection? I changed it in my Tazer and I think it's working how you would like - I'll check later.
AFD
Northeastern US
Iirc, the 'fog dropout' is to keep the fog lights active when the high beams are on (think that's unlawful in some states for some goofy reason).
Chip
Tom
Colorado Springs
sites.google.com
2022 JLUR XR
I just tried it and you are correct - Fogs stay on with high beams. Nothing changes with the auto light feature. Maybe take a rubber duck and cut a hole in the bottom to sit over the dash sensor? ?‍♂:LOL:
unsavory
Jimmy
Funny, but not exactly what we're asking for. We want the ability for the Auto selector position to turn on the parking lights during the day, and headlights at night.
  • Like
Reactions: AFD
AFD
Northeastern US
Lol. That actually might be a good solution for someone wanting to always have full headlights on all the time without ever needing to touch the dial.
I do appreciate you checking though!
Chip
Tom
Colorado Springs
sites.google.com
2022 JLUR XR
Hmmm.....I have a 2022 Rubicon with LEDs and that's the way it worked from the factory in the auto light setting. I did a quake led fender chop and they work the same way.
The only thing that doesn't work is when the auto switches the headlights on at night, the fog lights turn off. Parking lights stay on whether headlights are on or off.
unsavory
Jimmy
With the selector in the Auto position, and my headlights automatically switch on at night, my fog lights stay on. It remembers your last choice. So you merely have to press the fog lights button while it's in the Auto position to turn them on. Then next time they will automatically come on at night.
Also, the DRL or Daytime Running Lights do stay on during the day with the selector in the Auto position, but NOT the parking lights. I think you'll find that if you turn the selector to the parking lights position, you'll notice that those white lights on your front fenders get much brighter. This is the behavior we're speaking of. With the selector in the Auto position, those lights are much dimmer, and can be turned off in the UConnect settings under Lighting -> Daytime Running Lights.
I actually don't mind those white lights being dimmer in the Auto position. But the problem is that I want my fog lights to be ON during the day, like they are when the selector is in the Parking Lights position.
In other words, I would like the daytime Auto mode to behave as if the selector were in the Parking Lights position.
I've come to understand this isn't possible today with any known programmer, and it's a 1st world problem. So I just turn the knob when I start the vehicle instead, and have stopped using the Auto position.
  • Like
Reactions: AFD
