RUBYX 2door
Ua Nosnews
Ua
MN
2024 Wrangler Willys (soon)
Added a Molle Panel Solutions upper shelf on top of the roll bar.
How have you liked the upper shelf? How much space is there between the shelf and roof?
Soapy
Soapy
Idaho
2025 Wrangler Rubicon X 2 door
There is about 6 to 8 inches of space between the shelf and roof. The middle section of the panel is taller and the roof of the Jeep has a middle section with a lower area. That made it tight to get things in there unless you came in on the sides. I modified it by cutting out the center section of the new panel where the MPS logo is so i could put things up there easier. I bolted a strap along the bottom for support but not really sure that it would need it. I am not putting a lot of weight up there and it sure provides a lot of space and gets things off the floor and does not block the view out of the rear view mirror. Still happy that I did it.
Ua Nosnews
Ua
MN
Sounds good. Might give it a shot.
Soapy
Soapy
Idaho
I repositioned the light bar a while ago to put it under the bar and away from the view of the front camera. My Tyri 1010 spot beam lights came in and I replaced the flood lights I had with the 1010s for longer range of light.
Jeep Wrangler JL RUBYX 2door IMG_0442
Soapy
Soapy
Idaho
I added a hood decal to RUBYs big brother the Power Wagon so they would match. I was comparing a 285/75r17 Goodyear Duratac RT to my 35x12.50r17s on my Wrangler. They look almost equal in height. The RTs are going on my Canyon AT4X, the tire on the right is the stock tire Territory MT.
Jeep Wrangler JL RUBYX 2door IMG_0862
Jeep Wrangler JL RUBYX 2door IMG_0846
