Roll Bar speakers replacement
ocdrumbum
Frank
Lancaster county PA
2021JLU Rubicon
Attorney to be retired 12-31
I replaced my front speakers with the Terr Acoustics ones and WOW! They are incredible. I'd like to replace the roll bar speakers with a higher quality speaker that is plug and play.
Also was thinking about the lower front speakers. I looked at MB Quart for bottom speakers in the dash and instructins are basically you remover most of the dash to replace those speakers-not happening in my Jeeep
jludave
The Isle of Long
IT Manager
There really isn't anything truly plug-and-play for the larger speakers in the roll bar. You will need the speakers and an adapter. I have these:
https://www.amazon.com/gp/product/B084HLKSDN/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
This is the adapter:
https://www.amazon.com/gp/product/B0007WTEVM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
For the smaller ones, you can go with these, which are plug-and-play:
https://www.amazon.com/Mopar-Wrangler-Kicker-Speaker-Upgrade/dp/B004SUO5QS/
If you want anything larger, you will need to cut the speaker enclosure and use a speaker adapter/bracket designed for the size speaker you want to use.
1Evil55
here
2018 Sport
If you go with the brackets in the sound bar and some cutting is required, I highly recommend removing the plastic part of the bar and do the work on the ground. There is more wires that run through it than you might realize including the GPS which you may or may not use but would not want to destroy.
ocdrumbum
ocdrumbum
Frank
Lancaster county PA
2021JLU Rubicon
Ok so to install you unscrew the covers and remove stock speakers and tgen these fit in their place but you need the adapter cable
1Evil55
here
2018 Sport
Most shops that sell the speaker also have the OEM style connectors. Depending who you buy from, some throw them in free as part of the purchase.
jludave
The Isle of Long
IT Manager
Only for the larger speakers I linked. The other set have the correct connector on them sine they are a Kicker speaker designed for Mopar.
Blue Bear
Matthew
Seattle
2023 Hydro Blue JLUR
Air & Space Museum Curator
sailscall
Buffalo, NY
2021 2dr Sport 6MT
☝Those Select Increments look awesome. I installed the SI pods last year with Polk Audio 6.5” speakers and it turned out well. I think I spent $260 all in. $329 with kicker speakers and tweeters looks like a great deal. The best part is there is no cutting.
SGinn29
Ky
2024 jeep jlu wrangler
Too bad the select increments don’t work on the 24 non alpine system. the Map light is on the speaker grill now……
ocdrumbum
ocdrumbum
Frank
Lancaster county PA
2021JLU Rubicon
Ok I bought the plug n Play kickers and I just read instructions These are for JK???? No mention of JL
jludave
The Isle of Long
IT Manager
Same plug/connector. They fit in the JL and many other Chrysler/Mopar vehicles. These are a universal Mopar speaker made for Mopar by Kicker.
Don’t go by what you read in the instructions.
ocdrumbum
ocdrumbum
Frank
Lancaster county PA
2021JLU Rubicon
OK Just tried to install and these speakers are larger than the ones in the roll bar of my 2021 Roll Bar What do I get to repace the factory speakers looks like two speakers in the roll bar on left and right side. One small and other a bit larger.
Also what about the lower dash speakers? If I read correctly tou can't just remove the speaker covers and replace you need to remove a good portion of rhe dash????
Little Miss Trouble
Monica
Corona, CA
2018 Jeep Wrangler JLU
About to order these, looks easy enough... The smaller ones... are they for the sound bar too? SO all 4 speakers are for the Roll Bar??
jludave
The Isle of Long
IT Manager
