Roll Bar Self-powered Alpine Sub Install (Soft top Only)
PA JLUR
Cos
Doylestown PA
2020 JLUR
Sharing in case you are looking for a place for a sub......
Purchased a JLUR (soft-top) without the Alpine package. Didn’t want to spend the money and lose the cargo space. I have been happy with audio, but after removing doors and top..... I felt audio was lacking..... so I decided to add a self powered sub (Alpine PWE-S8) under passenger seat. Got sub and felt the fit under seat was no good. A buddy of mine suggested, the top of the front passenger roll-bar above factory sound bar. I bought a black cutting board from Amazon.... cut it down to create a mounting platform. Used two existing factory holes (likely for hard tops which I don’t have) and installed it. Added 3M film on factory painted surfaces to protect from scratches in case I change my mind and remove it all. I also used weather stripping between hard surfaces to avoid vibration. I pulled power, remote on, and ground wires up through the passenger side pillar. Then tapped into sound bar speaker wires. So far, so good. Definitely have the bass I was looking for and install was straight forward. Only risk to this set up might be in expected rain fall if top is off. Total cost of parts and materials was less than $300.
Jeep Wrangler JL Roll Bar Self-powered Alpine Sub Install (Soft top Only) 9E3CC5CC-0EE5-4DFF-8B3B-0E8868D0ED8A
Jeep Wrangler JL Roll Bar Self-powered Alpine Sub Install (Soft top Only) 2CF8071C-D219-4CCA-8F5A-99BD234CE393
Jeep Wrangler JL Roll Bar Self-powered Alpine Sub Install (Soft top Only) 5E8B17B0-F93D-42F9-894F-9C1C16553FA3
Jeep Wrangler JL Roll Bar Self-powered Alpine Sub Install (Soft top Only) 92A3A759-03A2-4F0F-88D6-AA7734A7962D
Rico1111
Rico
RI
2018 Rubicon 2 door JL
Can you please post up a pic with the top closed from the outside? That's a pretty good spot!
Terpsmandan
Penn Yan
Pretty sure it will not push up against the top when it's closed. There is a lot of room between the top of the sound bar and the soft top.
