Replacing Driver's Door Scuff Plate?
LSUjeep
Louisiana
Jeep Gladiator 80th Anniversary Edition and Jeep Wrangler High Altitude
azjl#3
North AZ
It's on with double side tape, it can be pulled off.
LSUjeep
Louisiana
That's all that whole piece is attached with? If I order a new one like in the link above will it come with the tape to reattach?
rahtx
Dallas, Texas
2025 Wrangler JLU Willys XR
Has anyone replaced that piece of interior trim that is on the floorboard right next to where the door sill guards go? Ours is horribly scratched. I believe this is the part for it and was wondering how easy it is to do.
This piece:
https://www.bamwholesaleparts.com/o...if3BLUTgL7hgOLwPPFbSOnjUbL5m3c1xoCgooQAvD_BwE
You have to disconnect the door wiring, check strap, and 1 bolt. After that, it's just held in by clips. This install video for Armorlite flooring shows it, although not in great detail:
LSUjeep
Louisiana
thanks - not too bad then
Ua Nosnews
Ua
MN
2024 Wrangler Willys (soon)
I've removed the passenger side panel before, and broke it. There are a lot of clips, and probably missed one before I tugged too hard. Go slow, and should be fine.
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
Make sure you keep the old clips, they cannot be purchased separately and they occasionally break.
LSUjeep
Louisiana
Appreciate it everyone
