Rear shock leaking
2018JLRUSellersremorse
Arthur
2021 4Xe Rubicon
My driver side rear shock is leaking. It should be covered by warranty. I might just want to upgrade looking for suggestions. Not looking to spend $1,000 for a set.
Thanks
Remorseless
NC
Thanks
A Fox 2.0 or Falcon 2.1 set would be an upgrade, but you're pushing that $1000 limit. You can get them both for under $1000, but it's closeish. The Fox set is a little cheaper (showing ~$700 for all 4 on Quadratec) or ~$930 for the Falcons. Depending on how close you're OK getting to that $1000 limit, those would be my suggestion if you want an upgrade.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
What don't you like about the stock dampers?
kah.mun.rah
Merenkahre Jr.
Duat
You can probably find someone here with a Rubicon take-off shock in their garage that they will give you for free to replace the damaged one. If you are going to upgrade, I would suggest buy once, cry once when it comes to aftermarket shocks. No sense lowering your ride quality by putting junk on a vehicle that costs $60K+.
carlhenry
carl
couch
1999 wrangler jl 2.0
i am looking for a front one for a Rubicon its a leaker
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Stock height?
entropy
Foothills of the San Gabriels
OF top 1% content creator
Thanks
I had two rubi shocks leak in less than a 3 years, as they were a bit too short for my "lift" and kept overextending. I upgraded to longer Bilstein shocks. $400 for the 4 shocks. They've been solid so far.
measure your shock mounts eye-to-eye and get something that fits nicely on your lifted Jeep. If your current shocks are too small for your lift that could be why it is leaking.
