Rear fender lining
TJEli
Eli
MI
Jeep, truck, car
Has anyone found an elegant solution to the plastic at the back of the rear wheel well? I have heat gunned mine and I cannot get it how I want it. It also still rubs at full compression and I am not going to put any more bumpstop in.
-Eli
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Seems like you need more lift or smaller tires.
TJEli
TJEli
Eli
MI
Jeep, truck, car
I don't need either of those. Thanks though. I can easily take the rear liners out and replace them with something aftermarket I am just wondering if there is another solution out there.
Zoobie
Seattle
2018 JLU
I had the same problem of the bump in on the rear fender rubbing at full compression with my 37"... I used a Dremel to trim the bump off. I'll probably replace longer term with a different fender liner long term... but it's fine for now.
